This normal?
FriedDumpling
Charlotte, NC
I noticed under my vehicle that the “pumpkin” appeared to be “wet”. It’s not, just a little gummy maybe from dirt adhering. But around the plastic button area, it had that appearance.
The picture makes it look bad, but the area is dry, no dripping, etc.
Is this normal? Any thoughts?
This is on the rear of the vehicle.
Brandon-w
Yukon
2015 Ram 1500
Had an oil change recently? Could also be a bit of pressuring check your vent tube make sure it's clear.
F
FriedDumpling
Charlotte, NC
Yes, probably in the last 300-500 miles at the dealer - though I’m not clear on the connection.
Can you tell me more about the vent tube?
Brandon-w
Yukon
2015 Ram 1500
They probly popped it out to check the level and left the residual instead of wiping it off. The vent tube is the rubber line that goes from the diff up to the frame. It allows the diff to vent without getting water in it. Sometimes they dust off and plug causing seals and plugs to leak.
F
FriedDumpling
Charlotte, NC
I did have the fluid checked previously, and they probably were a little sloppy. (If this is where they check it.)
Any reason to rush it to the dealer for an eval?
Brandon-w
Yukon
2015 Ram 1500
I wouldn't. Money is the pulled the plug and we're sloppy. If it was leaking they're would be more if a trail and it would be clean washing the dirt out of its way if that makes sense. Give it a good wipe down and keep an eye on it. Like I said it's likely the dealer. They may have even topped it off overfilled it a bit and slammed the plug in its only rubber and compression fit.
F
FriedDumpling
Charlotte, NC
Thanks so much!
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
The tech who checked your diff fluid and drew a ****, well played.
F
FriedDumpling
Charlotte, NC
pacofortacos
Looks like where oil came out during filling and they wiped it off - since it is oil it will be wet vs. the rest of the cover.
David H
USA RET
Minneapolis
RamCares
n/a
n/a
Hi FriedDumpling,
I certainly understand why this would be concerning. As you continue to keep an eye on this, if you decide to have your dealer take a look, be sure to let us know via PM. We are more than happy to provide you with an additional layer of support for that process.
Mark
RamCares
bryce88
Utah
My diff cover looked just like this after my dealer checked the diff fluid. It looked like this for a few weeks until it dried out again. Nothing to worry about, it just takes forever to look normal again.
