- Nov 16, 2011
- 2,643
- 8,068
- Location
- Central S.C.
- 2009
- Hemi 5.7
Still no issues running in Eco mode on my '09. Non-BT Pedal Commander.
My truck survived the upgrade. The PC is back and all is good in the acceleration world
Are all Pedal commanders Bluetooth now?
I only ask as I am looking into getting one finally (well wanted to get one months ago but life hasn’t allowed me time to upgrade truck till now) but see issues people have with the BT one. Are the issues only when using the app or the actual PC? I don’t think I would use the app and would change settings on the PC anyway.
Thanks for clarification
I keep mine at city +3 to sport +2 usually but I kick it up now & then. I think about running Eco but never seem to do it, no fun in thatWhat do you run yours at? I’ve currently got mine at -3 or four on sport mode, but all in all, I still haven’t really found a happy medium to run mine at as they all seem a bit to jumpy.
Im really thinking about getting one of these but this is not the first time I have heard of this device causing problems with the throttle position sensor. Is it possible for this to really fry it?
I have had my PC installed in my '14 Ram Express for about a year now. No issues at all, prior to the other morning and still not sure if it was PC related. Going to work the other morning and CEL came on and also the truck went into limp mode. Shut the truck off, restarted it and it came out of limp mode but CEL stayed on. Garage diagnosed/Repaired it. Throttle Position sensor on the pedal . I did remove the PC prior to taking the truck to the garage and the TPS was covered minus my $100 deductible of the extended warranty. PC was set on Sport, +4 I believe.
question haw to up grade the old PC no blue tooth can any one know the answer thanks
If you get a tuner does it make this thing obsolete or can you / should you use both in tandem?
