olyelr
Now, I'm all confused...I am under the impression that with the 17x10 AEV Katla, I could run up to 37's w/o concerns with rubbing. Looks like I am wrong?
You would be better off with the 8.5” wide ones.
Back on the OP's question: yes, you should cover that. It would be a pain in the butt, but if you remove the liner, you could get some sheet ABS (?) or similar plastic from amazon and epoxy in a patch panel.
