Hey man, no sweat! I dont know everything, but I do know enough to be dangerous LOL! And when I stated that I dont think a 3500 Ram ever had 5.13’s, its not factual information, its just what I think.
Thanks for posting up the info on those part numbers!
A little off topic, but did you ever run your 5.13’s with 35’s? I cant remember... just wondering what you thought of that combo.
I guess the shorter answer is the 5.13s and 35s were the perfect combo for my trucks configuration and use for the last 30k miles. I loved it, my favorite vehicle I've ever owned (after the regear).
Here's more on why but the long read can be ignored, the answer doesn't change but I do list my only concern.[emoji106]
i really really liked my truck with 35s and the 5.13 gears. It was such an improvement in my truck, I can't even describe the difference but I will try, in brief. Ok probably not briefly
We all deal with the heavy loss of HP through the automatic trans drivetrain, 20% loss give or take. I'd say with the 35s vs 33s, the poor trans gearing and poor trans control logic that 20% loss might even be conservative.
Also, We all deal with elevation losses, appr 3% every 1000 ft. I used to be at 7200ft but now 6900ft.
40% loss. Let's just say I was feeling the full truck weight, certified scale 7640lbs
I tried many of the bolt-ons thinking they could help the situation but a very tall ask. And really didn't get a whole lot from the driver-dyno, all said in done.
BUT I really liked the truck so I wasn't giving up. AND then she was born! With 50k on her clock, I had Colorado Gear and Axle swap in 5.13s and it fixed everything!! (Well not my foggy rear camera) It brought incredible life to the 6.4 and all the bolt-ons.
The only concern was on my weekly 220mi commute (one way) and the engine rpm at 85mph, 2600 to 2700 rpm.
Don't get me wrong, the gear wasn't too low unless the trucks main purpose is a long distance commute on a high speed interstate. If that's truly the purpose, constantly, then that configuration is probably off, imo.
I still make the drive but four times a year instead of but four times a year instead of 100. Now with 37s, I can say I miss my 35s. But I also haven't had it off-road since the tire change and that's is it's intended purpose from here forward. My daily driver with extended fun time duties. I can't get too off-road yet because, my front tires rub on compression with turn. My wheels are -24 offset so I went a little too wide to leave the suspension stock w 37s.
So, I am now struggling with the decision on suspension upgrade, Thuren Overland Extreme or Thuren King 2.5. I know the 2.5 system would be an amazing experience but am I really going to benefit that much with King 2.5? I don't drive crazy fast off-road, don't want to air-out the wagon.
Today, if I had to choose, 35s would be my choice vs 37s, but not quite a fair compare yet, soon as the 37s clear 100% at full lock and compression then I can drive it and I have a feeling the 37s will have quite the advantage off-road.
The 37s unfortunately brought back the low speed rear hop, where the trans lags or refuses to downshift unless I hammer the throttle. I didn't miss that **** with 35s. The hop really irritates me.
'16 PWagon with a badass Greene tune feed'n & Fire'n 6.4L 6spd // 5.13 AAM // 37" KM3, -24mm // DOR, Purple Cranium // CAI, ARH, Solo Mach44 // z36, EBC // Custom Graphics, AVS, 4% VLT // Morimoto, Rigid, Diode Dynamics // Alfa, Diablo //.................
