thatsnotstock
I have a 08 1500 2wd quad cab with 98k on it, Starts up in the morning after sitting all night with no problems and no lights. After 5 to 9 miles the Throttle Position light )z( will come on, engine runs ruff idles at 1200 rpm and no throttle response. No check engine light or codes picked up with a scanner. Replaced the TPS sensor assembly, ran with temp sensor disconnected with no change in symptoms. Once it is warmed up the TPS light will be on with key on, it will start but run ruff and limited to 1200 rpm.
Would this be a accelerator pedal sensor or another sensor causing this issue. I have searched hi and low and have not found one with the same issue.
Thanks in advance
Thanks in advance
