Tie Down Solution?
Cahriad
Reno
Looks like nobody makes a tie down rail with cleats that will fit my 2018 Ram 2500. I was thinking of buying L-track and fittings but not sure if the bed top rail will take the stress.
1stindoor
NC
'23 2500 MegaCab
I bought the Xtang Truck cleats. Had them for nearly 18 months...no issues yet. I think that L track would probably work as well depending on the load.
I'm also using bed rails.
mtnrider
Georgia
Probably work fine for light loads. Don't think I would trust it to ratchet down a heavy load? You can't use the factory tie-down points in the corners of the bed?
C
Cahriad
Reno
I actually want to bolt some things to it. They make a stud mount that I want to use to secure my propane tank holder and generator.FE200739_home.jpg
JayLuke
SO CA
CTD 6.7L
I usually end up fabricating something to suit my needs.
RandomRam
On the Oregon Trail
I looked at a used 2017 that had L track on the bed rail lip like you’re describing. Looked fine, but I’m not so sure how useful it would be. I’d rather have it down in the bed.
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
I always though something like a SS boat cleat in each corner would be ideal. The larege 6"-8" sizes but i just don't know how the best way to attach them so they can hold a heavy taught load. On my last truck I used about a 20" length of nylon strap and tied a squar knot in it as a loop and put that around my factory tie off points to give it more lenght a utility. It worked well.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
I have a headache rack on my truck. when I mounted the rack, in put one of the 1/2 inch bolts that goes though the rail 'backwards' then screwed on a stainless boat lift ring. rock solid, wouldn't hesitate to tie down a motorcycle using the rings.
the rear bed stake pockets I put bullrings. don't trust them as much.
They call me DLD
Eastern Time Zone
I purchased stainless steel pad eyes from a salt water marine supply house. Then purchased stainless countersunk fasteners (flat head) along with stainless washers and nylock nuts from Fastenal. The pad eyes that have four fasteners I located in the front corners of my bed. The pad eyes that have two fasteners are located on the forward side of the taillight boxes.
Skrap
Orange County, CA
DLD, how did you get the Nuts on the bolts? Isn't that all closed off? I like the ideas but dont see how you get to the bolts.
They call me DLD
Eastern Time Zone
At the rear, the taillights can be removed for access.
At the front corners a deep offset box end wrench worked well for me. Also, when I was drilling I had a buddy hold a wide blade putty knife between the cab and the bed so the drill bit would not puncture into the cab. Any piece of scrap metal would save you from embarrassment though.
loki223
Spokane, WA
Cummins 6.7
I have these on the rear stake pockets and the center ones (8 ft bed)
https://www.amazon.com/gp/product/B07WRFB9WQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
And these in the access holes inside the bed at the steak pockets
https://www.amazon.com/gp/product/B078BK5ZDH/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Overall, i like them. My problem is the tracks either are to large, or get in the way. I regularly haul random loads and pallets in the bed of my truck. While these are perfect for every situation, they do enough to get the job done.
Heres some pictures
VLG6963
