tie rod removal
JPT
NY
2015 Big Horn
Did you leave the nut in and hit the knuckle? If you hit the O around the pressed in tie rod, the vibrations usually pop loose the rod end.
jwheeler
Washington
Tie rod end puller? What have you tried?
usaf2006
usaf2006
North Carolina
Sorry for not replying. I was beating the heck out of it. Finally got it with about 40 consecutive whacks.. my problem is I don't have a BFH or any specialized tools.
JPT
NY
2015 Big Horn
A BFH is a must... Make a Home Depot run, you will need one again.
usaf2006
usaf2006
North Carolina
What should I torque these at? Can't find any recommendation anywhere... For upper ball joints either
