Time for a lift
sm10
2016 Power Wagon
I'm finally ready to pull the trigger on a lift for my 2014 RC 2wd Hemi. I'm going with maxtrac 4.5" spindles. I have 30k miles on the truck so far with quite a bit of off roading. Should I replace the front shocks while I'm at it?
I'm debating for the rear lift, Maxtrac 3" spring lift, or CST 4" spacer lift. I have 2" of rake right now and I don't mind the rake look. So with the Maxtrac I'll be sitting pretty much level. I'm wondering what is the difference between doing the spring lift versus the coil lift for the rear??? Is one better for the truck, problematic, wear and tear, etc....??? Please share any feedback or opinions.
Thanks,
Steven
Adept
4.7L v8
If you have a rake you can always buy bilstien 5100s. They are adjustable in the front and will level it on top of the lift. I'm not rest sure on the difference but word of advice get wheel spacers so there's no rubbing.
sm10
sm10
2016 Power Wagon
I went on ahead and ordered the maxtrac 4.5" spindle with 3" rear. The adjustable bilsteins are only for 4wd.
stevenmicheal
