LeesEvoX
- Oct 29, 2017
- 1,652
- 2,215
- Location
- Houston, TX
- 2020
- Hemi 6.4l
I did a soap test. The actual valve is leaking. I can see the bubbles. On both high. And low side.Is your A/c working now?, I would take a soap bottle and spray around the fitting, see where or if it is leaking, if its leaking a small amount through the Schrader core and it's coming out through the cap the seal on the cap is probably worn. You could just get a new cap with a seal to stop the leaking, that way you dont have to worry about using a Schrader tool and dumping the charge, really no need to pull the cap again unless you need to install gauges.
If its leaking around where the gauge port is saddled to the line then yeah will need to replace the line,
So I will get the tool (just to have it) and see if I can nip them tight. If not. Will ask the auto parts guys
Sent from my SM-G950U using Tapatalk
