Tire help.
RamHemi2500
North jersey
2015 ram 1500
Hello all. I have a set of 20x9 fuel coupler rims with a +1 offset in my 2015 Ram 1500 crew cab. I put the stick tires on which are P275/60r20. I want to get the Nitti Terra grappler G2. And would like to go a size or two higher and wider. I would like to know what size that would be and if it would fit without doing any mods. Thank you. New to this.
adrianp89
Tampa Bay, FL
I ended up just getting stock size Terra Grappler G2s. Love the look and they are beefier than the stocks. I did not switch to a bigger size because it was a $300 increase for the next size up, worse gas mileage, and a slower truck... wasn't worth it to me. Just some food for thought.
Rzrman328
The treeline
Whatever you find that works post your results here so others can see. Good luck.
SyN
6.7L CTD Owner
Tornado Alley
6.7L CTD
14hemiexpress
6.4l
At this moment I am leaning towards 285/55R20.
My Ram never leaves the Tarmac so these not really aggressive A/T will perform quite well. I am only concerned about Rain/Snow/Ice.
Good. Looking tire. Also found through research 305 55r20 is Pretty good size. Most tire ships can measure for you and help aid in getting you the right tire.
eljefe
Moyock, NC
Good looking tire. That tread pattern would look nice on our trucks.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I did the Nitto Terra Grappler G2, 285/65/20
Rims are 20x9 with 0 offset
MaizeNBlue
Just put these on last week.... front is leveled at 2.1" , stock wheels .... for now
Nitto Terrra Grapplers G2 285/65R20
Graygoose
Oklahoma
Convert, for now.
small
Sure, sorry, went home.
RamHemi2500
RamHemi2500
North jersey
2015 ram 1500
Thanks. I like this look. With my +1 offset I think that size will give it the stance I'm looking for. My stocks tires on the fuel rims stick out just a little. So with these it'll be a little more but not too much.
RAM-it83
