NorthEast4x4
- May 16, 2022
- 8
- 1
- Location
- Connecticut
- 2022
- 5.7 HEMI w/eTorque
Does anybody know the recommended tire pressure for the 2022 Ram 1500 with night addition?
It’s the Pirelli scorpion 22 inch tires.
I got the truck and the tire pressure was 52psi. I’m assuming on delivery the dealer forgot to set it properly. I’m pretty sure when the truck is in transit they put the tire pressure super high so that there’s less abuse on the truck’s shocks. I just checked the door jam and it says 36 psi so I adjusted it down to 36 but just wanted to get some opinions on if that’s the best psi for this tire. Also, should all 4 be the same or higher/lower in fronts?
I’d rather the vehicle ride a little harder but have more protection for the 22 inch rims. What would you guys recommend for the tire pressure?
The door jam just says 36. It doesn’t give you any high or low recommendations so I wasn’t sure if there was a specific band for high and low temperature as I can sit in the middle of or be on the high end for protection. Certainly over 50 psi is way too high.
Thank you
Thank you
