Cham
2019 2500 Tradesman 6.4L 4X4
Two things..
a) My tire pressure low warning came on the other day for the left rear tire. I had set them all at 45psi. I brought them all up to 50 psi. Left rear still shows low and alarms. Ended up bringing it up to 75 psi before it would stop alarming. the other three tires are still at 50psi. It reads 4.8 metric whatever that means, I use an ordinary TP gauge to read the actual value. I like to run the lower pressure because I don't often have a load in the truck, and I was finding the recommended pressure was wearing out the centre tread of the tires (still factory what-ever-they-are). Is there a way to reset this sensor or whatever reads it to something lower like maybe 40psi?
b) Is there a way to switch the display readout to show PSI instead of metric? At least that would make it functional, at least to me.
-C.
Two things..
-C.
