I’m just curious but what pressure does the manufacturer of your tires say to run them at, or have you even asked? I’m only curious because my brain thinks that because I was told to run my 8 ply bfgs at 55, that your 10-ply’ers would be even higher.
I never bothered to contact the manufacturer. the tires I have at the moment were never meant to be long term tires. I got them because I needed tires fast and cheep. They are Maxtrek MUD TRAC. I Iaven't decided what I'll replace them with specifically, other than that they will be name brand, and more of an AT tread design.
Anyway, back to the topic at hand. I learned a long time ago, not to just take someone's word for it when it comes to tire pressure. I had tires put on at a tire shop years ago, and they said to always go by the vehicle manufactures recommended pressure, regardless of the tire size. In the 20 miles trip home, the tires were heating up, and the outer edges of the tires were already showing wear from being under inflated. That's when I learned about chalking the tires.
And just a few years ago, at the dealership where I bought my ram, they had the tires (had 35's at the time, but a different brand) inflated to the max pressure listed on the side wall. When I questioned the service tech about it, his response was, "Oversized tires need more air pressure." I'm guessing the previous owner thought this as well, because the center tread was worn almost bald on all 4 tires, and the outer edges still had plenty of tread.
In short, I'm of the opinion that there are too many variables for anyone to say "you need to run xxPSI." I'll stick with chalking my tires, and just know that if I have a failure, it's on me.
Also, How long have you had your BFG's? Have you noticed any accelerated tread wear in the centers?
Edit:
I could be wrong, but it was my understanding that the higher the ply count, the stiffer the sidewall. and that with a higher ply count/stiffer side wall, you also got a higher max pressure rating and higher weight capacity. But along with all that, when unloaded, the stiffer sidewall meant that you could run lower pressures than a similarly sized tire with a lower ply count.?
