Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Tire Pressure
Discussion in 'Heavy Duty' started by AWLINK, Feb 11, 2021.
  1. ridgeracing
    ridgeracing Junior Member
    49
    19
    Nov 8, 2020
    Pa
    Ram Year:
    2020 2500 Tradesman
    Engine:
    That's my thoughts as well. I am fine running 65 in front. But my truck rides horrible being empty with 65 psi in rear. Take it down to 50 psi and it rides much better and tire still has no sag as compared to frt. Not to mention it gets better traction VS bumpy/chatter in rear
  2. SniperDroid
    SniperDroid Senior Member Military
    65
    106
    87
    Aug 30, 2020
    Eaton Township, Ohio
    Ram Year:
    Engine:
    It was 5*f this morning when I went out to the Truck. Threw the low air pressure warning because it went below 60 pounds in one rear tire. Had to run it up to 70 psi to clear it. Ill be looking into AlphaOBD to clear this one up. I like to run about 65 in the front and 60 in the rear when empty. Bump the rear to 70 when towing the travel trailer at about 7500 pounds.
    ridgeracing likes this.
  3. Lucy Girl
    Lucy Girl Military, Army Veteran Supporting Member Military
    74
    685
    474
    Nov 27, 2018
    Mt. Vernon, Texas. 75457
    Ram Year:
    Engine:
    3.6 V6
    What ever they happened to put in. lol
  4. loveracing1988
    loveracing1988 Senior Member
    3,485
    901
    Jul 4, 2013
    Clarkston, MI
    Ram Year:
    Engine:
    Yeah, this is true on a half ton truck, but when at 80psi my rear tires are missing half of their contact patch I consider that a bigger safety issue.
  5. ridgeracing
    49
    19
    Nov 8, 2020
    Pa
    Ram Year:
    2020 2500 Tradesman
    Engine:
    After dealership blowing me off saying they cant do anything I called RAM. Talked to a glorified secretary that passes information to engineering etc. she called me back and said they cant do anything either! Very upset that they do this to a 50K truck and I have to either feel every Pennsylvania bump etc. or deal with a warning light and gauge showing low rear tire pressure. The truck is empty going down the road, no reason for 65+psi!! My rear tires are not going to wear wrong because I have 50-55psi in them as well as no weight in bed or towing!
  6. HEMIMANN
    HEMIMANN Senior Member Supporting Member Military
    62
    738
    1,805
    Dec 7, 2020
    Minneapolis, MN
    Ram Year:
    2017 2500 Laramie Crew Cab
    Engine:
    6.4L HEMI
    Guys - read back........it's not FCA's fault - it's the NHTSA mandating this.
    loveracing1988 and ridgeracing like this.
  7. ridgeracing
    49
    19
    Nov 8, 2020
    Pa
    Ram Year:
    2020 2500 Tradesman
    Engine:
    Copy, just frustrated. Just seems ridiculous to make a setting so high, not every 3/4 ton truck drives around loaded. And even with 55-60 psi in rear it can haul axle/weight according to tire manufacture well above empty weight of truck.
  8. Scotts26
    Scotts26 Senior Member
    216
    292
    Apr 12, 2020
    Ram Year:
    Engine:
    Just spend the $150 bucks and get the AEV Procal Snap and be done with it. 5 minutes and no more TPMS light. I’m running Falken 35’s on my 2020 Power Wagon at 45 PSI front and 40PSI rear.
    https://www.aev-conversions.com/product/procal-snap-hd-ram/
  9. cash4acres
    cash4acres Senior Member
    144
    84
    Mar 8, 2016
    Newport Beach CA
    Ram Year:
    Engine:
    6.7L,660ftLbs=G56 Manual 6 speed
    Youtube tips search=
    Cheap Frugal Trucking
    28mpgsTampa2OrlanfoFl
    29mpgsSanAntonio2Houston
    20degrees avg temperature
    26mpgsElPaseo2SanAntonio blizzard 20s, 50%4x4
    27mpgsTucson2ElPaseo
    29mpgsVegas2phoenix
    25mpgsDallss2ElPaseo air temperature 10-25 degrees
    24mpgsPensacola2Dallas air temperature 20s & 30s
    32mpgsMiami2Tampa80psi
    29mpgsDaytona2TampaBay
    31mpgTampa2Naples2Miami
    28mpgsTampa2Orlando
    29mpgsTampa2Miami
    29mpgsFtMeyrs2Miami
    32mpgsKingman2Phoenix *
    NewOil 10-60w pennzoil platinum plus premium oil
    32mpgsSanBerna2LasVegas
    31mpgs MorroBay2SanFram
    30mpgsVegas2Laughlin
    31mpgsEugene2Portland
    27mpgsVegas2Portland
    30mpgsDallas2BullHeadCity
    April 21-24,2020
    26mpgVegas2Texas coldair
    29mpgSanAntonio2Houston
    28mpgElPadeo2SanAntonio
    30mpgVegas2Phoenix
    26mpgMississippi2Vegas
    30mpgPortland2AmarilloTx
    27mpgTacoma2Portland
    26mpgOhio2ldaho
    24mpgPennsylvania 2NC
    27mpgMephis2Pensacola
    28mpgGreenBay2Chicago
    27mpgIndianapolis 2GrRap
    28mpgJacksonville 2 WaDC
    31mpg Ok City to Dallas Tx
    27mpg Houston to El Paso Tx
    27-33mpgs freeway 60mph
    18-20mpgs city driving 10-18mpg off road
    10-18mpgs tow 6kLbs Boat
    2015 2500 Tradesman Cummins 6spd 4x4 4door Deleted 4" pipe, KN flat washable air filter Engine & cabin. Camper shell EdgeCts2
    Baja front Cow Deer Grill
    2front light bars=570watts
    1st responderCERT 10k lbs. TransforceHt 2757018 tires
    Deleted PFdiesel.com @78k
    25-32mpgs freeway
    15-20city,
    10-15 off road
    Efficiency is measured TonXMiles per gallon used by scientist in the diesel truck industry.5.2tonsX28+mpg= 146TonMile/gallon
    Toyota Prius is 3200=1.6tX50 mpg=80TonMile/gallon
    Railroads 500ton mile/gallon
    18wheeler 7x20=140tonMile
    6 way MPGs calculated=
    1-RAM computer
    2-Garmin gps
    3-Google maps gps
    4-USGS maps Android
    5-AAA maps Android
    6-hand=4 semesters calculus
    Cummins diesel ECO TIPS
    1:Speed 55-65 mph
    2: Close Windows
    3: No items on top of car
    4: Make truck aerodynamic
    5: Inflate tires maximum 80?
    6: High rear end gearing3.42
    7: Factory tall tires 70s
    8: 5-40w Synthetic Oil
    9: avoid 4x4 driving
    10: Remove excessive weight
    11: Fuel is heavy too
    12: Plan journey wisely
    13: warm up engine
    14: clean outside
    15: Avoid RAIN
    16: No aggressive driving
    17: Don't over-rev.
    18: Gear fast, slow accelerate
    19: Avoid idling.
    20: Overdrive & cruise control
    21: Ele&AC worsens MPG
    22: Exploit cruising down hill
    23: Avoid a complete stop
    24: red>roll in neutral gear
    25: Tune engine to low HP
    26: Change oil regularly.
    27: Replace air filters asap
    33: Leave early Family drama
    34 constant Mph=Mpg
    36: avoid drama & stress
    37 Park in shade
    38 cruz2 save braking
    39: Forced induction =MPG
    41:Rough asphalt tire wear7%
    42:Use brakes to slow down
    43change fuel filters often
    44change power train oils
    45avoid wider tires
    46avoid jacking truck height
    47used tires =better MPGs
    48TenDegrees=HalfMileMpg
    49 rpm 1400-1600
    Obama Diesel Exhaust Cooker warranty expired 80k. 3rd Cooker by 75K so @78k I deleted.
    Saving fuel & costs 10c mile = $1000/10,000 miles
    Or $10,000/100k miles
    So if I deleted, 300,000 = $30,000 fuel & cost savings 2016to2020
    Some attack so I fight back. 151IQ. Top1%USA. 780+ escrows 750+ text books 4 semesters calculus. On 6th passport. 8 states gun Ccw permits. 199 court cases. Own 8000+ acres California no loans since 1991. No drug's smoking or booz. American Red Cross VIP blood donor card since 1991. fico 826+ IMG_20210225_175729779.jpg
  10. ridgeracing
    49
    19
    Nov 8, 2020
    Pa
    Ram Year:
    2020 2500 Tradesman
    Engine:
    I purchased AEV Procal Snap , installed in minutes and took care of TPMS. Works great!
Share This Page
