Tire pressure
P B Casterlin
NEPA
2019 3500 Dually
6.7 Cummins HO
Is there any way to lower the air pressure and not have the tpms light flash? 60 and 80 psi seems a bit much when I am not towing or hauling. I'm sure the ride would be better.
Sent from my SM-G960U1 using Tapatalk
chris1126
RAMINA
pa
you can use it to program, activate, deactivate features on your ram. search it on google or theres probably 10k threads on here about it. good investment.
P B Casterlin
P B Casterlin
NEPA
2019 3500 Dually
6.7 Cummins HO
Thanks, I will check it out.
BigTJohn
6.7 CTD
My '14 3500 has TPMS but only if I scroll to it in the EVIC can I actually see the tire pressure. Will the Alpha allow for an alarm if tires lose pressure?
chris1126
RAMINA
pa
not sure i understand your question. when your pressure gets below a set amount, the warning goes off.
2012RAM1500RT
nowhere
You can get rid of TPMS with ALPAOBD if you want. I have a 2012, not sure what all years it will work on otherwise. I spent $400 plus trying to make my TPMS work right. Got tired of fooling with it and now my evic doesn't even show it since I got "RID" of it! I know when I have a low tire on my own, I've been driving for more than 1 day!
