Tire pressures for 285/60/20 Micky Thompson Baja Boss A/T
mreservices
WV
2016 Ram Laramie 4WD
Looking for a recommendation on a starting tire pressure for 285/60/20 Micky Thompson Baja Boss A/T. When I go to tiresize.com and use their tire pressure calculator, based on the OEM P275/60/20 @ 39 PSI (door sticker), it says I should start with 44psi. Does this sound correct. I will eventually try doing a chalk test to confirm but just trying to start somewhere close. I appreciate your advise.
audiophile
5.7L
I used to run a tire store and Normally I would say stay with the placard and factory recommended pressure. However, since you are moving to a LT tire, 44 would be sufficient. My truck has LTs from the factory and they are 43 psi.
Socalramfan
Huntington Beach
2011 Big Horn
Granted I have Yokohamas, but mine run at 50psi unloaded, and 60psi when towing. So, no…. 44 does seem high at all to me.
mreservices
mreservices
WV
Thank you guys for the assistance. I will start at 44 and do a chalk test once I get the alignment done. Have a great evening.
1Popeye
