Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Tire size change alfaOBD
Discussion in '4th Gen DIY' started by Redheadhunter21, Nov 9, 2018.
  1. JayLuke
    JayLuke Member
    58
    17
    Dec 11, 2019
    SO CA
    Ram Year:
    Engine:
    CTD 6.7L
    I've successfully changed the tire size using Alfaobd on: 2010 Dodge Ram 2500, 2015 Ram 1500, and 2016 Ram 2500
  2. RamVol
    RamVol Junior Member
    43
    Oct 28, 2020
    North Carolina
    Ram Year:
    2019 Ram 2500 Big Horn
    Engine:
    Has it been confirmed that these steps will work on a 2019 Ram 2500?
    Some say you have to do the Vehic Dynamic Tire Value.
    Also, do they have My20 on the OBD yet?
  3. David_411
    David_411 Junior Member
    30
    28
    25
    Dec 18, 2019
    Alberta
    Ram Year:
    Engine:
    I'm having major issues.
    My truck is currently not functioning.
    I've done this multiple times previously with no issues.
    Alfa OBD changed the App,
    I no longer have a ABS/Ate option.
    I used the ABS Bosch/Continental/Teves/TRW PowerNet
    However I still have dash full or warning lights and error messages.
    I've never had this before.
    Please help!!!
  4. David_411
    30
    28
    25
    Dec 18, 2019
    Alberta
    Ram Year:
    Engine:
    Where is this "module reset" procedure?
  5. 1500ram12
    1500ram12 Senior Member
    5,299
    2,099
    Jan 23, 2012
    Ram Year:
    Engine:
    6.4L Hemi
    Try connecting to abs/ecu/bcm and clear any codes in each. If they come back, I believe there is still the static ecu and clearing rolls that needs to be done. I haven't used alfaobd in months so I'm not sure what changed in the abs section
    2018 2500 6.4L Hemi Tradesman
    1990 5.9L 12v Cummins W250
  6. RamItGood
    RamItGood Junior Member
    38
    25
    Apr 24, 2019
    Ram Year:
    Engine:
    I got a question on the steps, when doing every step, after it, do you turn truck off and let sit for 5 minutes before advancing or do you not need to for tire setup?
    Thanks
    MathanDubh likes this.
  7. MathanDubh
    MathanDubh Junior Member
    47
    Nov 2, 2020
    Virginia
    Ram Year:
    Engine:
    Hemi t.7
    My version of AlfaOBD won't even connect to the ABS Bosch/Continental/Teves/TRW PowerNet. None of the selections work. How do I connect to a 2017 Ram 2500 ABS?
    MD
  8. MathanDubh
    47
    Nov 2, 2020
    Virginia
    Ram Year:
    Engine:
    Hemi t.7
    Re my post above. Does anyone have an idea how I can get the correct module into the AlfaOBD selection menu? Can't seem to find a way to report it.
  9. 1500ram12
    5,299
    2,099
    Jan 23, 2012
    Ram Year:
    Engine:
    6.4L Hemi
    You don't have to for tire size changes. It's more for if you are changing multiple different settings that can cause the truck to freak out
    RamItGood likes this.
  10. MathanDubh
    47
    Nov 2, 2020
    Virginia
    Ram Year:
    Engine:
    Hemi t.7
    Need the ABS module to fix he errors that pop up after changing the tire size
Share This Page
