Tire size
devrock1730
US
v6
Anyone run 295/65/20 on factory black 20 wheels on 16 ram 1500 no lift? I want beefy and taller.
buddy guy
alberta
When I change out my stock tires I would like to go 295 60 20. I was told not an issue with at least a level (2.1" on my 2018 Ram). But 295 without the lvl would be dicey. Other thing is finding 295 65 20. Pretty rare so very pricey. Guy at 4 wheel parts looked at their inventory and while we found tons of tires not one 65 option. Also with the offset of factory rims that would be too close to a rub situation for me. Maybe you'd be ok trimming. Don't want to do that on my wheel liners.
Sent from my SM-N960W using Tapatalk
BOWERSFJ
Uniontown OH
No lift or level ... Go 295/60R20 ... Still wider and taller
D
devrock1730
US
v6
Currently has 275/60/20.
Pezrock
New York
Can someone confirm a 275/65/20 on all stock truck fit without issue?
Michael
In an undisclosed bunker
You’ll want to level for that size of tire. I think you would also want aftermarket wheel with at least a 0 offset. If you really want to keep the stock wheels you’ll be running spacers so you don’t rub.
I know the voices in my head aren’t real, but man, do they ever come up with some great ideas.
cory1385
Manheim
I’m running 295/60/20 atturo trailblazer xt on my 2017 1500 no lift no level and no rub even at full lock but it’s a tight fit.
cory1385
Manheim
Atturo trailblade xt sorry
BOWERSFJ
Uniontown OH
Nope ... He might “want” to, but he wouldn’t have to ... Post right above is proof
Michael
The post above was for a slightly smaller tire. The previous post listed a 295/60/20 which is a little over an inch shorter then the 295/65/20 the op was asking about. The post before I bet that that tire is also on aftermarket wheels with a different offset them the oem wheels the op is wanting to use. Here is my truck with 295/65/20’s on it with a 2.8” level. The wheels have a 0 offset. Imagine the front of the truck sitting 2.8 inches closer to the tires. It wouldn’t take much to rub. The clearance I have between the tire and the front suspension would be gone with the oem offset and I’m sure the tires sidewall would rub on the suspension.
cory1385
Manheim
Nope I run those 295/60/20 on stock chrome clads. I have 3/4” gap to the a arm and at full lock there’s still 1/2” of clearance all around no trimming necessary. That being said the atturo runs about 34.8” x 11.5 wide and I’ll admit the 295/65’s would not clear, yes you could trim the shroud but no way around the suspension without some kind of offset. That’s on a 2017 bighorn not sure how that differs from other models.
Badger 13
North Idaho
2013 Dodge Ram 1500
I have Goodyear Wrangler Duratracs LT275/65/R20 on the stock wheels with no issues.
cory1385
Manheim
Here are 295/60/20 on stockIMG_1947.jpg
Thale51
TN
I'm looking at going to 295/65/20 for my next tires as well. I'm currently running 275/65/20 Cooper Discoverer STT Pro's with a 4 inch lift.
Badger 13
North Idaho
2013 Dodge Ram 1500
I was referring to post #6. Sorry if I miss understood.
cory1385
Manheim
295/65/20 do fit after trying a friends on my stock but if you want to turn anywhere your going to need to trim a good bit atleast on mine. It did clear suspension however. The tire also did not have much tread left. Just figured I’d let you k ow and try it for you.
