18tfh
On the 2020 Ram 2500, what’s the difference between the stock 18” tires and optional 20” when it comes to ride quality? Don’t plan to do much off road, mostly towing a travel trailer. Thanks.
Much smoother is a stretch, I think I've had both and there isn't enough difference to eliminate 20's. Your carrying more psi in the 3/4 and 1 tons which makes both stiff sidewalls. Get the look you like.18” will be a much smoother ride.
Hello Forum,
Tires on my truck are 275/60/20 and my spare is a 17" What the heck...! Looking for 17" or 18" rims and tires
Welcome onboard!
I bet if you measured that 17" tire, it would be the same overall size (rim+rubber) as the 20", or very close. My father had the same thing on his 2015 Laramie. My 2014 Longhorn, before I traded it, came with a 20" spare, but only because it was added as an option back then.
My new 2020 came with 22" rims and an 18" spare.
