tires
Jeremy Lynch
Knoxville, tn
2019 new body
can my 2014 ram 1500 2wd with no level or lift run 285 60 20 A/T tires with out rubbing
Jeff CA
NorCal
Yes. Those are only 1/2" larger diameter and 10mm wider than stock, so you won't hit fenders or suspension components.
Jeff CA
NorCal
Highly, highly doubt they'd fit with a stock susp.
Blue and Maize
Fla
Not sure what you ended up going with but the biggest on a factory 2wd 20 in is 285 60 20.
Toyo r/t
