Titan 51-Gallon Fuel Tank for Cummins Mega Cabs
Discussion in 'Heavy Duty' started by AzRamLover, Dec 22, 2016.
  1. AzRamLover
    AzRamLover Senior Member
    40
    433
    91
    Oct 29, 2014
    Ram Year:
    Engine:
  2. ramcumminssix
    ramcumminssix Junior Member
    29
    12
    Oct 22, 2018
    billings
    Ram Year:
    Engine:
    Cummins 6.7
    the government/EPA regulations make it virtually impossible to do larger, replacement and auxiliary tanks for gasoline. So in-bed tanks with a pump can be done for gasoline. I like how titan has a in-bed tank for gasoline that goes over the wheel wells. I use it to refill snowmobiles and dirt bikes.
  3. Don_T
    Don_T Member
    97
    21
    Nov 30, 2017
    Ram Year:
    Engine:
    6.7
    Because of this I went with a 40 gallon in bed tank with a pump. Not my preferred way but it works.
  4. reloaderguy
    reloaderguy Senior Member
    554
    290
    Apr 26, 2015
    Oregon
    Ram Year:
    2016 Power Wagon
    Engine:
    The Hemi and Cummins trucks use the same exact fuel tanks. Titan technically doesn't make a tank for 2013+ CCSB trucks because the emissions are in the way. The tanks are the same for all 4th gen trucks though (per chassis).
    PaulTGarrett likes this.
  5. Punishher7
    Punishher7 Senior Member
    293
    199
    Aug 15, 2016
    Ram Year:
    Engine:
    So the 51 gal “diesel” tank would fit in my ‘18 PW? Would the plumbing be plug and play?
  6. reloaderguy
    554
    290
    Apr 26, 2015
    Oregon
    Ram Year:
    2016 Power Wagon
    Engine:
    The plumbing is plug and play. However, the Evap canister is mounted in front of your existing tank (where the new larger tank sits) so you need to figure out how to relocate or delete it.
Share This Page
