To ceramic coat or not?
cms1528
MD
If you ever have to have a panel or spot repainted after a repair be certain to tell the bodyshop you have a ceramic sealer on there. It has to be removed or the paint won't adhere probably otherwise.
bill-e
New Hampshire
3l EcoDiesel 3rd Gen
The DIY coating ads are a little misleading. While the coating itself may be comparable to a professionally installed one, what really makes the coating look great is the surface prep, which by the way, is the largest part of the professional installation cost.
Personally if I wasn't going to do my own paint correction I would opt for one of the wipe on sprays.
wifi_guy
Northfield, MN
6.7 I6 Cummins HO Turbo Diesel
What exactly is the paint correction doing? Curious.
bill-e
New Hampshire
Paint correction is preparing the paint so that it looks as good as possible. Removing all the scratches and blemishes as much as possible before applying the coating. Defects can be visually amplified by the coating.
wifi_guy
Northfield, MN
Gotcha. Makes sense.
Thmw
Conroe TX
5.7 Hemi e-torque
So since i have a brand new 1500 paint correction isn't needed right? I can just do a simple wipe/spray on of the chosen product??
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I still would, even brand new cars may have say outside, or transport.
I did a brand new 2018 392 Daytona, right off the lot, and the difference was huge!
joeygster
Ancaster, Ontario
Graygoose already mentioned it but the vehicle finish still gets wear and tear and still might need it. In particular most dealerships hire young kids with no detailing experience to clean, wash and wax the cars and that process wreaks havoc on the finishes of their new inventory.
If you're really OCD, many pro detailers will tell you that the best thing to do is factory order and tell the dealer not to remove the plastic that comes with the vehicle from the factory. Your detailer does it and it saves alot of the paint correction work.
Perferd
Windsor, Ontario, Canada
Good call on telling the dealer not to fully unwrap and have the vehicle detailed. I never thought of that and am now emailing my dealer to do that. The plan was to send the truck for tinting and a detail on their end but I'll just tell them to have the tint done and that's it. From there I'll take.it straight to my detailer who will do a paint enhancement then a detail while I maintain it for a year to save for a full correction and coating...
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Excellent decision!!!!!!
Jay
Mike0565
NY
2016 Laramie crew cab
I have an appointment to have my 16' CC laramie done professionally in late May. Doing paint correction, glass, plastic, and something for the wheels, (heat treated) or something like that. It's supposed to last for 3yrs with a refresher for the following 2yrs. The one question I have is, after the 3rd year and it's reached its protective limits, can I go back to waxing?
bill-e
New Hampshire
How long the coating lasts depends on a lot of things, climate, care etc. If you do regular maintenance, depending on conditions it could last 2 years or 4 years. Having said that, once the ceramic properties are gone then yes, you can go back to wax, or one of the growing list of quality spray on ceramic products.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
I am about to do a ceramic coating on a neighbors Durango next weekend and possibly finally doing it on mine lol .... I am going to be doing all paint correction this coming week on my truck and will take my time doing so ... ooooh yeah .... I have to remove some water spots from my wheels as well and will coat those fawkers too ...
Mike0565
NY
Thanks
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
IMHO--the new Graphene coating is worth a look if you have a choice.
Jay
2018 2wd
Jay
Only thing about graphene is that you have to have a completely flat surface for it to work correctly ... one high spot can ruin the whole coating .... right now graphene is still not up to par with ceramic coating ....
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
That has not been my experience with the SPS Graphene Coating. I like it almost as well as Polish Angel. Any high spots no matter what coating you use will ruin your day. Gotta check carefully.
Jay
BROWNMATHTEACHER
HINESVILLE, GA 31313
2019 Ram Bighorn Lonestar
5.7 liter hemi
I had my 2019 Ram 1500 Bighorn coated professionally in mid March 2021. I have to do a maintenance procedure once a year with the detailer that coated the truck as part of my warranty.
