To lift or not?
crazykid1994
Alright so going against all my original ideas here but I’m contemplating a 4” lift kit and ordering new fox front coilovers at the same time and going to 1” over for a 5” lift front and purchasing 3” rear gladiator springs. I may do the 2” lift blocks and keep my eibach springs for a bit though. Possibly zone? If I go that route I’m debating a rear box kit from procomp to drop the rear control arms instead of the relocation kit that the zone kit uses. Part of the reason I’m thinking about this is because I am currently at 3” front 1” rear and after off-roading last time I did bottom out a few times plus I’m trying to gain some down travel back by using less preload. Plus that should be a lot easier on my cv axles too. Then I’ll build true sliders and a full belly skid. Already have a design in mind.
CanRebel
Toronto
Curious why not looking at going to 6" lift? Price wise, if I recall are pretty close.
Socalramfan
Huntington Beach
2011 Big Horn
Do it :waytogo:
crazykid1994
crazykid1994
They are close and I could run stock height coilovers and that would be 5” lift. I don’t want to go higher than 5”. For me higher is not better. The 4” kit with some preload should in theory give me a bit more clearance to the front crossmember over a 6” kit with no preload. I need clearance but want more wheel travel.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
Originally we had to do the 6” to get the 3” rear coils. Now it’s available with the 4”. The brackets are identical with both kits from zone the only difference is the strut top spacer in each kit.
Do the Fox full length coil overs or even the icon for the lifted applications and you’ll never look back
crazykid1994
crazykid1994
What’s the benefit to full length coilovers? Looking at the fox 2.5 dsc. I’ll be installing gladiator rear coils for the multi rate with extra payload so I won’t be buying the zone 3” rear box kit. Just 2” blocks since I have the 1” eibach springs currently and then I can swap to 3” springs later.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
@crazykid1994 was this the Pro Comp rear box kit you were talking about ?
crazykid1994
crazykid1994
Yes it is.
crazykid1994
crazykid1994
Did you end up getting it ? ...
I have not. Waiting to see what my work bonus is. I need new struts at the same time. If it’s a good bonus I’m going to do the lift as well. I’ve actually been leaning towards the 6” kit and running coilovers set to 0 and run that rear box with 4” rear springs
czervika
Punta Gorda FL
Necro post... What were the rear springs you're looking at? I think I need the extra inch due to the topper, tent and extra load being carried when I head out for camping.
JamesCrowe
Canada
Would longer and adjustable trailing arms and track bar not be a better performing option for the rear than a bracket relocate?
This is my first truck without leaf springs so pardon my ignorance. It's been a while from my Jeep days.
I know the front is more difficult. Is there a mid or long travel kit available with different LCA/UCA and longer CVs with more angle?
Cmz2800
NC
Your axels will be taking a beating. Like people suggested: you’re better off with a 6-inch lift.
olyelr
Kewadin MI
From my understanding, most of the 4” kits come with the same drop cradle as the 6”…no? Why would his axles suffer?
Cmz2800
NC
Really? I was under the impression that the 4” didn’t come with the cross member replacement. I’m probably wrong.
olyelr
Kewadin MI
Yep, they definitely do. Usually, anything under 4” is touted a leveling kit and dosnt drop the diff or low a arms. Maybe not the aev but i honestly dont pay much attention to the half ton stuff.
crazykid1994
crazykid1994
Yes. The 4” and 6” use the same crossmembers. I have since redacted that idea. My truck has stayed at the 2.5” lift height. I have no real need to lift my truck 6-7”. It’s a dirt road/woods truck. I don’t do rock crawling. This setup has never let me down.
Cmz2800
NC
I drive to work and back. Like myself, I think like 95% of people that lift their trucks do it for aesthetics. Same with wheels & tires.
