To those with 20 inch chrome clads...
Ryan51993
Massachusetts
Hi guys this is my first post but definitely won't be my last, I'm the owner of a 2016 ram 1500 with the 20 inch chrome clad wheels. Up until now my wheels have been holding up really well and I've had zero issues with them. Well I had my trusted mechanic do a brake job and tire rotation and it came back with one hub cap cracked almost all the way around the bolts. I mentioned it immediately and he tried telling me its a well known issue and happens to everyone with these wheels. So my question for you guys who have these wheels is whether or not this is really a common occurrence or if he actually wrecked my wheels and is just trying to avoid paying? I've looked and looked and found absolutely nothing online about the chrome clads randomly cracking apart. If they really are that fragile and all my wheels are going to end up this way I won't push it with the guy and I'll just go aftermarket. Otherwise its going to cost me around 200$ just for a used wheel because as far as I can tell the hub caps aren't replaceable so I really want to know if I should be going after this guy for the money.. Any input is appreciated, thanks!!
Naldo1710
If the mechanic broke it he has to fix it. If it is a known issue, they should had told you BEFORE starting the work in order to make you aware of it. For example radiator hoses that are old tend to crack when you replace other components. A good place will tell the customer that and prepare the customer for some potential costs due to damage that is known to occur. I think your mechanic is full of it and I would not go back to him.
BOWERSFJ
Uniontown OH
I have a 2012 with chrome clads ... I change em out twice a year in the spring and fall for my summer wheels, and I have never had an issue ... Also have never seen that issue mentioned here ... To be honest, the chrome finish has held up amazingly well through 6 Ohio winters ... Any way, I’m gonna say the meathead over-torqued them with the impact gun, and broke the chrome clad ... To take this one step further, while over-torque is not good for your wheels, it way worse for your new rotors ... I’d back em all off, and torque them properly to 125 ft-lbs ... Then go back and tell the guy he owes you a new wheel
JohnnyMac
SouthWest Washington
2018 1500 Laramie
3.0 EcoBurner
Agree with the others. It's not a known problem, and he screwed up. If it was a known problem, he should have taken extra steps to prevent it from happening or like @Naldo1710 said, he should have advised you that it was a possibility and he wouldn't be responsible before he did the work. Not sure how much trouble it will ultimately be to collect, but he owes you a new wheel.
** Edit ** Welcome to the forum BTW.
muddy12
Indiana
I’m with Bowersfj.
I also have a 12 that just hit 90k miles. I rotate my tires at every oil change (3 to 5k miles), and all 4 of my chrome clads look great.
Here’s a pic from a few weeks ago when I put on the new tires. Rims are a little dirty, but no cracks.
chrisbh17
Sounds to me like they zipped the lug nuts on with an impact and cracked the plastic in the process.
Make them get you new wheel(s), then never go back there again.
I once watched Town Fair Tire (a popular "discount" tire chain near me) put the lug nuts back on my dads Crown Vic with an air impact. Sure enough 6 months later when we need to change the brakes, one of the lug studs was cross threaded and snapped when we tried to take the wheel off. Of course we had to fix that ourselves....on a Sunday....in the rain. Needless to say, I refuse to even walk into one of their stores anymore.
Fast69Mopar
I have seen a total of 2 cracked chrome claddings in the 15 years they have been released for Ram Trucks.
Your "mechanic" is full of sh*t and should be honest and cover the cost.
If it were me, I'd remove the chrome cladding from the rest of the wheels. Clean the paint up under the cladding and run with the satin silver wheels. Then I would Plasti Dip the covers.
PolarisCobra
Mendon, MA
I have a Chrysler Pacifica, 2006, 195000 miles. The Chrome Clad wheels on that look great. I know the design is different, but these things hold up amazingly well.
R
Ryan51993
Massachusetts
Wow I'm blown away by all the quality responses on this forum you guys are great!! You all pretty much confirmed exactly what I was thinking. After reading your responses I felt confident in calling the guy up and saying look I did my research you're full of **** I want to be compensated or I'll see you in small claims and he took the full cost of a new wheel plus mounting/balancing off my bill. Thanks a lot everyone!!
BOWERSFJ
Uniontown OH
Way to go ... I luv it ... Didn’t take you long ...
Cableman
Longisland
Theres kinda a void in-between the clad and the wheel itself, just from glue.
The kid who mounted new tires on my 08 used a cone on the front to hold the wheel on the machine while removing tire, that caused the plastic to flex and crack off the chrome.
I dont see how lug nuts could have done this as they bottom out on the wheel not the clad, he had to apply pressure to the clad or used it as a jack stand lol.
Were the tires rebalanced at all?
turkeybird56
Central Texas
^^^^^^^^^^^^^^^^^^^^ Same as all above said. ALSO< make sure You tell Mechanic to not IMPACT them on, but to snug them, THEN USE Torque wrench to 130 Ft Lbs... My SA at Dealership knows me and my thoughts. I even carry torque with me and prior to leaving, get out my wrench and check torque in front of SA with my wrench with 6 Point 22 MM socket, and confirm torque. IF they hammer them on, might take (2) big *** grown men to use a cheater bar to get em off. Ask me how I know, <LOL>, had that problem on an F150 on side of highway.
tbird71
Lake Placid, FL
I've seen em PEEL especially between the lugs but never CRACK
I'd tell him to talk to you or your lawyer...his choice
BOWERSFJ
Uniontown OH
Post #9 ... Issue resolved
Whammo
Agree with the rest of the folks I've got a 2016 w/thre same wheels - they have been flawless.
ShotCaller
He probably won't admit his mistake, so be prepared to go to small claims court to get him to pay.
Do you have any real proof that he did it? It might be hard to get any money back in this case.
** Just saw post #9..... Glad it worked out for you !
BOWERSFJ
Uniontown OH
Again, post #9, issue resolved ... Lol
ShotCaller
yea just saw # 9. Glad it worked out for you !!
Ibsledge
Tx
I owned 2 different rams with that set of rims . One I had for 7 1/2 years that was parked in the driveway daily in the hot sun . Never had a issue and when I traded they thought it was still new.
Jonnyb
Cape coral
5 th Ram since 2013. All clad wheels. Damaged two times when getting new tires installed and fixing a flat. Otherwise they hold up great. Before any tire service I make the service writer walk the truck with me and confirm no damage. Another instance all the lug nuts were damaged beyond use. I had a tire rotation and a rear end service in the two weeks prior. Couldn’t prove who did it. Always check before service
