Tools to make JBA header install easier?
Throwin Plugs
New York
Hey guys, putting in my headers this weekend and I should be pretty well covered for the install. Have plenty of tools in my box from my old mechanic gig. However, those of you who have installed them before are there any specific tools you could recommend that you wish you had at the beginning? Stubby wrenches. Flex heads etc? Just wanna make sure I got my bases covered. Thanks!
Beer and a fair bit of it,lol. Is your truck a 4X4? If so the bottom dipstick bracket will give you some issues.Good chance you won't be able to get the bolt out of it completely.I back the bolt out ,then work it in and out a few times till you can spin the bolt easily by finger,then cut the head off the bolt,and you can usually remove it by finger then.If you cut it close to the head,you can clean it up and turn it into a stud and just pick up a nut at your local hardware store,if you screw the bolt,you can grab another a bit shorter,or make a stud out of a longer one.Been awhile but i think it's a 8mm X 1.25 bolt ,but don't quote me on that,as i'm older then dirt and alzhiemers has been known to kick in occassionally,lol:gr_grin:
Remflex 6022's are one of the best gaskets you can use on them,they also make a good 3" 3 bolt collector gasket. If you have a swivel socket like this,you can usually get at all the bottom bolts using it and a long 3/8" extension. Unhook the steering column at the knuckle,but "do not" turn the steering wheel tie it so it won't spin ,a rope/tie strap etc. wrapped around the wheel ,and closed into the door will hold it from turning
This style 6 point swivel socket in probably 7/16" and 10mm will make the job easier.Damn it looks like they're gold plated now though.I bought my sets years and years ago,sure glad i did,lol
Snap-On 4 Piece 3/8'' Drive 6 Pt SAE Flank Dr Shallow Universal Socket Set (FS) | eBay
Throwin Plugs
Throwin Plugs
New York
Awesome response! Thanks a ton. I was just gonna use gasket maker for the y pipe, I did buy felpro gaskets though for the headers themselves.
These are shorties and not long tubes then.For shorties the gasket maker is what you probably want.For some reason i thought you meant long tubes,for those you need a 3" collector gasket,my bad.
indept
South Jersey
X2 on the highlighted sentence.
As for the socket, almost $40 US for a socket is way expensive, even for snapon, especially used. That person is trying to rob you.
DILLIGAF
Canadian Forces
Canada
I just bent my OEM oil dipstick out of the way and bolted it down. Been 5 years now zero issues.
-i3BN8Uou7VudCF2Qa1FXsVXMw771Cf7hnSKVWDBg7_H40KTmXbwddIM8FgoM9c6FCfdhaunMQf_nnpPF7EtGT0I-STd6oOagAw3nab8ztnd-lsjPtjl4vUilCnHMMeemkLyQzTrcGWrNI02sFX-1cM5J6eT-jltk_W9GxoB2PpcHNkme3rSS1bmF66RsJLK4WSzJYbdRJXKf3ULkd9A9K-GkiH380vimZZyAGtMyAEp9hglX9PVgKOJwF2unEszFzdfwi_qW8qBX5Ffdv860_TVI9040wAZW5ShaYPGyCDmAEaPpIS0KBCRxgpaQcXK-7r7G5Esx3juGWsTwTncIXVt10WY94799F72fY4yR-N4CLuGtJyrjpS8Kp73R1IrXtY2bmrrpABmfaftq5PI-eS8ORs6MCRmwvFYZVRKuoHP7x7jXgH2dJ8ks61EXTDpfUnOo-I2Nsx7fpZxR8QQpH9kN_o291xGEVPgabVf_loo79Sv6LubD3_plPP0nz-h848jBAUBUTyFRxxa5aB7TFxdGAsV-9ZVFxcj_DmD6HhU-4WRd_z3bSEioJBxmQf4W5FK3j_QzYB8xWut8VLfkGDnorYTVS0oDFbQSvMjeFndEJZSuEaPpFuZghAy1xmyiHaDfOfhtuKNfF0mcUyBi3Af58OlLs9rUEotHaJWjDU2Yh10FsBESDji2ggDTfPkdSgd4vcDXu3NAAt_UxnppieaNg=w1920-h960-no
Throwin Plugs
Throwin Plugs
New York
Yeah I meant to say these are the shorties. My bad!
Throwin Plugs
Throwin Plugs
New York
Luckily I have thise (not snap on but similar). Crazy money
Snap-on no longer makes them as far as i can tell,and it looks like guys are selling used ones for a gouge and screw price. I have the full set of them in both SAE and Metric,and i'm thinking i might be able to retire off them,by the looks of the used prices.
Throwin Plugs
Throwin Plugs
New York
Looking forward to the install. I used to take ARD heads, fuel pumps and turbos out CAT C7's and duramaxs. This shouldn't be any worse as far as cramped space.
Pull Ya
Cedar Creek, Tx
Good luck with the install, one word of caution though. No matter how much experience people have I can't ever remember reading anywhere that someone said, "Damn, that was fun I wished I could do another set". Wild one is right about the beer--it makes it all better--LOL
Jay
Throwin Plugs
Throwin Plugs
New York
Jay
Lmao maybe I should grab a sixer on my way home.
bigred90gt
If you are using the JBA bolts, get a 3/8" flex head ratcheting wrench. I had to use a standard 3/8" wrench, and the amount of turn you can get on some of the bolts is literally a few degrees at a time. The flex head would have allowed better access, and the ratcheting wrench would have saved a ton of frustration.
Throwin Plugs
Throwin Plugs
New York
Just picked up a set last night after studying the bolt layout. Good call!
bigred90gt
I bought a full set of metric and sae ratcheting wrenches just for this job. When it came time to install them, after I already had the manifolds out, I realized they sent me 2x 7/16” and no 3/8” in the set. I may have cussed them as I chugged a beer in disappointment.
Throwin Plugs
Throwin Plugs
New York
Thats rough. I just bought 2 sets (one of each) from duralast. They seem just as good as my matco wrenches, if it breaks I get a new one. I double check it had a 3/8 lol
James OBrien
St. Louis
5.7 Hermi
Throwin Plugs
Throwin Plugs
New York
Welp shes in the air, tires off, fender well covers out. Pulled the heat shields off for a check and PB blasting, no broken bolts or studs thank god.
Unfortunately it started to drizzle and I ran outta light (gotta do it in the street unfortunately.) So I'm biting my nails knowing it's on jack stands over night (to be fair I stuck 2 more under the front cross member jussstt in case. Hopefully it goes smooth in the AM!
