Torque specs for rear upper & lower control arms?
bskl76
Bako, ca
5.7 liter Hemi
Hey there, just got some spohn performance rear upper & lower adjustable control arms for my 2/4 mcgnaughys deluxe drop. If anyone has torque specs it be much appreciated? Thanx in advance.
4x4Hemi
Edmonton, Alberta
I believe its 250ft/lbs.
there was another post on a guy getting em and he said he had trouble with em cuz they were such a high torque spec. thats all i got it from
BlkRamRt
SoCal
HEMI 5.7
Like 4x4hemi said i also thought it was 250.
B
bskl76
Bako, ca
5.7 liter Hemi
Thanks guys. Just wanna make sure before I tear into my suspension. Can I get a third person to confirm this? Thanks in advance
Lawhand
Baton Rouge, LA
250 foot pounds.. thats insane. it cant be that tight i was able to take mime off with a 1 foot breaker wrench. no way my 140 lbs @$$ was able to get off 250 foot pounds while laying on my back under my truck with a 1 foot breaker wrench. It was 85 foot pounds on my ford lightning. i am about to reinstall my spohn bars again as well. would be nice to have a number.
DavidRam
SoCal - Redondo Beach
2012 RCSB
Does anyone know the correct torque specs for upper and lower control arms???
I am getting some movement on acceleration and deceleration and I called Sphon and they said the control arms aren't tight enough.... They should be tightened to factory specs. But they didn't know what factory specs are. :(
By the way, they said this a common problem and they hear it all the time.
Anyone?? Thank you!
Edit: I kinda doubt that it is 250 ft lbs or is that me being clueless?
UneasyJmitchell
Louisiana
I forget which "section" but one of the threads sections has a torque list for almost everything on the Rams in the list. Ill look around for it.
Etroze86
Grand Forks ND
Someone on this site has to have access to AllData or Michlle to get factory specs.
BlkRamRt
SoCal
HEMI 5.7
got this from another forum
Chassis Torque Specs
(4th Gen RAM)
Shock Absorber Upper Nut --------------------------------------------------------------40 ft lbs
Shock Absorber Lower Bolt -------------------------------------------------------------100 ft lbs
Shock Tower to Frame -------------------------------------------------------------------55 ft lbs
Lower Ball Joint Nut Initial Torque------------------------------------------------------ 35 ft lbs
Lower Ball Joint Nut Final Torque ------------------------------------------------------148 ft lbs
Upper Ball Joint Nut -----------------------------------------------------------------------70 ft lbs
Lower Control Arm Frame Nuts --------------------------------------------------------200 ft lbs
Lower Control Arm Axle Nut------------------------------------------------------------ 200 ft lbs
Upper Control Arm Frame Nuts --------------------------------------------------------120 ft lbs
Upper Control Arm Axle Nut ------------------------------------------------------------120 ft lbs
Stabilizer Bar Frame Bolt ----------------------------------------------------------------45 ft lbs
Stabilizer Link Axle Bracket------------------------------------------------------------ 110 ft lbs
Stabilizer Link Stabilizer Bar Nut --------------------------------------------------------27 ft lbs
Stabilizer Link Axle Bracket (Power Wagon)------------------------------------------ 110 ft lbs
Stabilizer Bar Nut (Power Wagon) -----------------------------------------------------110 ft lbs
Hub/Bearing Bolts -----------------------------------------------------------------------149 ft lbs
Axle Nut - 132 ft lbs Beginning Torque, Then Rotate 5 to 10 ~ Times With a Final Torque of 263 ft lbs
Track Bar to Frame (2500/3500 4x4) -------------------------------------------------200 ft lbs
Track Bar to Axle (2500/3500 4x4) ----------------------------------------------------200 ft lbs
Tie Rod End Nut ---------------------------------------------------------------------------55 ft lbs
ABS Assembly Mounting Bolts -----------------------------------------------------------11 ft lbs
ABS Assembly ABM Screws -------------------------------------------------------------31 in lbs
ABS Assembly Brake Line Fittings -----------------------------------------------------170 in lbs
Dynamics Sensor--------------------------------------------------------------------------97 in lbs
Wheel Speed Sensors, Front Sensor Bolt ----------------------------------------------190 in lbs
Wheel Speed Sensors, Bracket To Knuckle ---------------------------------------------60 in lbs
Wheel Speed Sensors, Rear Sensor Stud--------------------------------------------- 200 in lbs
ABM Mounting Screws --------------------------------------------------------------------53 in lbs
RWAL Module Mounting Bolts ------------------------------------------------------------11 ft lbs
RWAL Valve Brake Line Fittings --------------------------------------------------------170 in lbs
Rear Wheel Speed Sensor Mounting Bolt ----------------------------------------------200 in lbs
Brake Booster Mounting Nuts ------------------------------------------------------------21 ft lbs
Master Cylinder Mounting Nuts ---------------------------------------------------------160 in lbs
Reservoir Retaining Screws ----------------------------------------------------------------6 ft lbs
Caliper Bleed Screws ---------------------------------------------------------------------14 ft lbs
Caliper Mounting Pins, Front -------------------------------------------------------------24 ft lbs
Caliper Mounting Pins, Rear --------------------------------------------------------------22 ft lbs
Caliper Adapter Mounting Bolts, Front (1500) -----------------------------------------130 ft lbs
Caliper Adapter Mounting Bolts, Front (2500/3500) -----------------------------------275 ft lbs
Caliper Adapter Mounting Bolts, Rear (1500) ------------------------------------------120 ft lbs
Caliper Adapter Mounting Bolts, Rear Upper (2500 and 3500) ----------------------163 ft lbs
Caliper Adapter Mounting Bolts, Rear Lower (2500 and 3500) ----------------------190 ft lbs
Junction Block Bolts, Front (1500) -------------------------------------------------------14 ft lbs
Junction Block Bolts, Rear (1500) --------------------------------------------------------18 ft lbs
Junction Block Bolts, Rear (2500/3500) ------------------------------------------------7.5 ft lbs
Brake Pedal Assembly Bracket Bolts (1500) --------------------------------------------23 ft lbs
Brake Pedal Assembly Bracket Nuts (2500/3500) --------------------------------------21 ft lbs
Support Plate Mounting Bolts/Nuts (1500) ----------------------------------------------75 ft lbs
Support Plate Mounting Bolts/Nuts (2500/3500) -------------------------------------150 ft lbs
Brake Line Fittings, Master Cylinder -----------------------------------------------------14 ft lbs
Brake Line Fittings, Junction Block (Both) -----------------------------------------------14 ft lbs
Caliper Brake Line Banjo Bolt, Front -----------------------------------------------------20 ft lbs
Caliper Brake Line Banjo Bolt, Rear ------------------------------------------------------20 ft lbs
Brake Hose Bolts To Frame, Front ------------------------------------------------------7.5 ft lbs
Brake Hose Fitting ------------------------------------------------------------------------14 ft lbs
Parking Brake Pedal Assembly (1500) ---------------------------------------------------18 ft lbs
Parking Brake Pedal Assembly (2500/3500) -------------------------------------------14 ft lbs
Hub/Bearing Bolts (1500) ---------------------------------------------------------------120 ft lbs
Rotor to Hub Bolt, Rear (2500 and 3500 DRW) ---------------------------------------114 ft lbs
Extension to Rotor Nut, Front (2500 and 3500 DRW) --------------------------------128 ft lbs
Hub/Bearing Bolts, Front (2500 and 3500 4X2) ---------------------------------------130 ft lbs
Pitman Arm Gear Shaft Nut (2500, 3500) ---------------------------------------------177 ft lbs
Drag Link to Pitman Arm (2500, 3500) ------------------------------------------------100 ft lbs
Drag Link to Tie Rod (2500, 3500) -----------------------------------------------------100 ft lbs
Drag Link Adjuster Clamp (2500, 3500)------------------------------------------------- 40 ft lbs
Tie Rod End to Knuckle (2500, 3500) ---------------------------------------------------78 ft lbs
Tie Rod End Adjuster Clamp (2500, 3500) ----------------------------------------------40 ft lbs
Stabilizer Bar Link to Axle (2500, 3500) -------------------------------------------------50 ft lbs
Steering Damper to Axle or Linkage(2500, 3500) -------------------------------------75 ft lbs
Steering Damper Bracket U-Bolt Nuts (2500, 3500) ------------------------------------45 ft lbs
Track bar to Axle - M16 fastener (2500, 3500) ----------------------------------------200 ft lbs
Track Bar to Frame - M16 fastener (2500, 3500) -------------------------------------200 ft lbs
Lug Nut 9/16 X 18 with 60° Cone ------------------------------------------------------130 ft lbs
Lug Nut 9/16 X 18 with 60° Cone (2500, 3500 - SRW) -------------------------------140 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (3500 - DRW) ----------------------------------145 ft lbs
Lug Nut 9/16 X 18 with Flat Washer (4500, 5500 - DRW) ----------------------------148 ft lbs
Spare Tire Winch --------------------------------------------------------------------------15 ft lbs
Jounce Bumper Bolts ------------------------------------------------------------------21.5 ft lbs
Shock Absorber, Lower Nut/Bolt --------------------------------------------------------100 ft lbs
Shock Absorber, Upper Nut/Bolt -------------------------------------------------------100 ft lbs
Spring Clamp U-Bolt Nuts --------------------------------------------------------------110 ft lbs
Spring Front Nut/Bolt to Frame ------------------------------------------------------254.5 ft lbs
Spring Shackle Nut/Bolt, Upper/Lower -------------------------------------------------160 ft lbs
________
atc06jh
Middle Georgia
(4th Gen RAM)
________
You just saved me some time. I thank you for this list sir!
