Torsion Keys and Adjustable Shocks
VolsRam
Franklin, TN
HEMI 5.7
I'm needing to get new tires soon, and would like to upgrade my wheels and tires to be more aggressive. I want to level the front end to fit the larger tire, but I'm not very familiar with torsion bars. I know I can get keys to level the front end, and I know on 4th gen Rams you can get Bilstein 5100s and adjust the shock to level the front. My questions are (1) can I get by with doing one or the other to level my front end or (2) do I need to do both?
Gray ram 2004
I just did the keys. They clear 33x12.50 20ds just fine
chrisp2493
Always Modding
Warren, OH
392 Hemi
Just crank the bolts up about 8 complete turns. Lift the truck up to take the weight off the tires, spray some lubricant on the bolts and crank them 8 turns. It’s about 2” of free lift. The keys do essentially the same thing, just the bolts aren’t tightened in as far. I’ve had mine up for over a year and no issues
chrisp2493
Always Modding
Warren, OH
392 Hemi
What bolts................?
In the crossmember that holds the torsion bar keys, there is a bolt that holds the torsion key into place. By tightening that bolt it raises the end of the torsion key, which twists the torsion bar further, which raises the front suspension. 3c61ebeba77fea38175bb0bd14aaaa7b.jpg
chrisp2493
Always Modding
Warren, OH
392 Hemi
Torsion lift keys you can buy basically come pre-adjusted so you don’t have to tighten the screw to get the desired lift. But you will have to rent or buy a special tool to unload the torsion bar, remove and change out the keys, then reload the tension with the clamp tool to reinstall the adjustment screw.
To use your existing key just jack the truck up, tighten the bolts 8 turns, lower the truck and measure the difference. It’s way easier, cheaper and yields the same results
MarkV
Ontario, Canada
4.7 Magnum V8 NOW with Moose Power
I did this to my truck. No problems in 2 years.
Captain Freon
Massachusetts
magnum 4.7
Thanx for the tutoring, bud!
SYKRAMMAN
Banned
Jersey shore
06 Mega
Do the 6+ still have torsion bars? I thought they changed to coil overs in the front? No?
chrisp2493
Always Modding
Warren, OH
392 Hemi
I’m not really sure what year they actually switched the suspension. My buddy’s 08 had coilover’s.
VintageSpeed
Can I adjust this on my '03 RWD Hemi Ram? It's different on the 4x4's, right?
I want some more tire
Canada
06 would be the first year of coil overs.
If I recall the 2wd are a coil over, so you’d need lift coils.
WhiteExpress
Midland, TX
No, you cannot. Only 4 wheel drive trucks have torsion bar front suspension.
You would need either coil spacers (Boo), Lift Coils (still kinda boo) or Spindles (Least boo). Largely depends how high ya wanna go.
That 57 hemi
Virginia
Okay I’m in a little different boat here, I’m looking at getting 7 inches without a body lift.... if I buy new keys just to be new and crank them up 2 inches while having a 5 inch lift will this give me 7 in the front ??? For the back I would add a spring or two and a 3-5 inch block... would this be possible?
2016Bighorny
Wisconsin
I cranked up the bolts on my old 2003... looked great and level.
I had zero issues while I had that truck...
