tow/haul -engine brake training
bartbill
diesel
tow/haul- engine brake .
Question for those of you who drive mountain passes. On long steep down-grades, do you use
1. tow/haul only.
2. Tow/haul with engine brake (or is this the same thing)
3. Jake brake only?
Burla
2010 Hemi Reg Cab 4x4
How much are you towing?
Maybe it turns on when you plug in trailer?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I used tow haul and the exhaust brake if the road called for it.
you have both and its fine to use both or either one by themselves.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
1. tow/haul only.
3. Jake brake only?
You don't have a jake brake...only an exhaust brake.....2 different things.
Only big rigs have jake brakes.
Harold Blakely
Sacramentoca
I'm wondering if there is any ware to engine. I have 2500 5.9 towing 7000# 5th wheel.Would using exhaust / engine braking be good to use and does it save that much on brake ware. Which is most cost effective. Standard braking or eng braking. Cost about $2K to install, right$
averageguy
Belleville Mi
hemi
I do know that if the road is slippery using the transmission or the engine brake can potentially cause a jack knife because the truck is braking and the trailer is rolling free pushing it.
Tumbleweed
When I had my 2010 Dually w/ the 6.7 Cummins in it, I ran the exhaust brake ALL the time, except in bad weather conditions. Constant use kept the turbo vanes moving freely. That and the fact that the emissions junk fell off!!! ;-)
1Popeye
