That's true If you have existing hooks. Those of us without hooks from factory dont have that bolt. The other bolt that gave me trouble is the existing frame bolt which must be removed as it doesn't have the half hook insert like the other bolt you are referencing doesFor anyone else wanting to remove/install tow hooks; you don't remove this bolt.
The tow hooks are designed that they can slide on to (and off of) the loose the bolt, you just loosen it, put the tow hook a little past the mounting point and around the bolt and then pull it away from the truck (towards the front) to have the bolt seat in the correct location on the tow hook then tighted it right back up.
The same goes for removing them, you can just loosen the two bolts on the frame (not remove) and just lightly pound the front of the tow hook towards the back of the truck and they slide off the bolts.
Source: Removed mine today for powder coating.
