Tow mirror marker lights
PCT
2019 2500 6.4
Northern California
Is it possible to rewire, the orange lights in the tow mirrors to stay on constantly like a running light or marker light?
R.L.K.
Bristol , Tn.
I'd say it is possible .
I suppose you could pick up a 12vdc switched power on the PDC if you wanted them on whenever your fob is turned to on/ACC . Maybe install a relay off the switched power to an inline fuse then split it and run to the mirrors lights.
I may be over thinking this , you may just be able to run them to your light dial , but then you'd have to select a position on the dial for them to turn on .
Maybe someone will chime in on this , I'm interested to see what others have done .
bendodge
There is a how-to I came across on how to do this. I will see if I can find the info and post it.
R.L.K.
Bristol , Tn.
Just think of a diode as an electical flow check valve ( like with a fluid check valve being 》》》》》directional , on the diode direction of flow is indicated by circular bands on one end . If you install a diode and do not get the results you wer expecting just flip it 180° , you have a 50/50 chance of getting it correct even if you don't know about the band's .
Reactions: PCT
PCT
PCT
2019 2500 6.4
Northern California
Gotcha the write up made it seem not to bad! Ill probably be doing this comming up
MoreOvalteenPlz
Stillwater, OK
PCT
PCT
2019 2500 6.4
Northern California
