DodgeDipDiveDuck
Hi there, I recently bought my first truck that I plan to work on. It’s a 4wd 2010 1500. I’d like to have it moved approximately 40 feet forward into a heated bay. I plan to winch/push it in there but I want to make sure I don’t damage anything in the process.
From what I’ve read online, both the transmission and the transfer case need to be in neutral in order to flat tow/push the truck without causing any damage to it.
In the owners manual, starting the engine is part of the procedure for putting the transfer case into neutral. I’m unable to do that though as the engine has already been disconnected from everything and is partially disassembled.
My plan was initially just to put the transmission in neutral and push it, but after reading that, it seems like that would be a big no-no. Would like some advice as it’s my first truck and I definitely don’t want to damage anything. Sorry in advance if this is a dumb question.
