Towing
Huh?? ... LOL
Apparently rear end gear ratio doesn't matter but if an exact clone of your truck was made and had 3.21 gearing and your truck has 3.92 gearing... Which one would you want to be behind the wheel of in a race to the next stop light(0.4km away) from a 20 roll??
3.21 it's going to carry 1st gear alot farther then the 3.92 geared truck,the 3.92 truck is going to be shifting out of first way sooner from a 20 mph roll,and will also make one more gear change,and every gear change loses you time. My truck was as fast with 3.21's as it was with 3.55's Phil.It depends on your power band more then anything,i built mine to build torque,and it spun the rollers to 572 lb-ft at 3200 rpm,but only made 500 rwhp ,so the taller gears worked as good or better then shorter gears,but if your truck has a bigger cam,and is built more for top end power,then the 3.92's might be the better choice. I kicked my ass for ever believing Green and going to 3.55's,i knew i should of followed my gut,but at the time i figured he knew more about the trucks then i did,20/20 hindsight afterwards,lol
You are correct, the left front gets pulled up, but I already knew that. However, the torque counteracts the engine weight so the left front wasn't getting ripped apart but rather having the weight of the engine removed from it. As one would expect, that's not the one that kept failing. Right front has the torque adding to the weight, and surprise, surprise, that's the one kept failing! Sorry, the owner's manual made no mention of having to add a chain to keep the motor mounts from failing. :Big Laugh:
With a diesal i might give you that,especially a lump of a 6.2 cast iron GM diesal that's just a touch lighter then the Titanic,but we're not talking heavy diesals here,we're talking light weight aluminium headed gas pots,and they tear the drivers side mount apart,and don't weigh enough to crush the passenger side mount,lol.Chaining the drivers side down,also lessens the weight transferred to the pass side mount,as the engines torque is now split with some of it applied to the drivers side frame rail,reducing the torque applied to the pass side mount
Administrator
@Wild one ok so don't answer question about the taillights... LOL
you went further into the torque/gear relationship of drag racing than expected :oops:
Tail lights we don't need no stinking tail lights. LOL. I'm just having fun with this thread now,it was getting to serious,so i thought a little humour might lighten the mood :Big Laugh:
ramffml
ramforum
Huh?? ... LOL
Apparently rear end gear ratio doesn't matter but if an exact clone of your truck was made and had 3.21 gearing and your truck has 3.92 gearing... Which one would you want to be behind the wheel of in a race to the next stop light(0.4km away) from a 30 roll??
Wait. The guy with the poky little diesel is concerned about 0 to 60 now?? :emotions34:
Y
yrraljguthrie
Sulphur, Oklahoma
etorque5.7
The transmission or the axle ratio does not change torque. Going up a hill with a 3.21 or a 3.92 rear axle requires the same torque. There are two ratios at work, one in the transmission and one in the axle. Together they allow the engine to rev to the required rpms to get the pickup up the hill. The transmission CANNOT change the torque, period. If it did we could just use a little two-banger engine and let the transmission provide the torque. The engine is pushing the truck up the same hill and the SAME torque is required in both cases. There are no increased forces in the transmission. The job of the transmission is to even out the forces and allow the engine to do its job. If more torque were created either by the engine or by your special transmission then the truck would climb the hill faster or climb a bigger hill. Same hill, the same speed, the same engine speed, and the same torque. When the axle ratio is dropped from 3.92 to 3.21 then the transmission needs to be shifted down to get the same overall ratio. The engine sees the same resistance. How could the engine know if the ratio was changed in the axle or the transmission? The 3.92 axle may be required to operate the transmission in the highest gear if the load is large enough. The transmission doesn't "work" as in making an effort, it facilitates the work of the engine. So far as increased gas consumption. The truck using a 3.21 using 7th gear should get the same fuel consumption as the 3.92 in 8th gear. Or thereabout.
I think he's talking more about the torque applied to the pinion then anything,and he is right. 3.92's do require less pinion torque then 3.21's do,but by the time the applied torque transfers through the ring gear and makes the right angle turn to the axles and tires,the applied torque to the axles and tires equals out as the ring gear equals out the final drive ratios. 3.92's in a higher gear are applying less engine torque to the transmisions output shaft/driveshaft and pinion,then 3.21's in a lower gear are applying to the same output shaft/driveshaft and pinion.In that sense the man is correct. The torque applied to the tires is the same between the 2 ratio's as long as both have the same final drive ratio's,but from the pinion ahead,the 3.92's do require less applied torque
You have to think of how the transmission multiplies the engines torque to wrap your head around what he's talking about.
3.21's in a lower gear are multiplying more of the engines torque to the driveshaft then the 3.92's in a higher gear are.
Even though i was giving him a hard time about his motor mount theory,the man is correct,but the motor mounts are more then robust enough to handle the extra twist applied to them
ramffml
ramforum
And that's why it's so important and why I keep saying: "real world".
If you look on paper only and say "what do I need", you can end up with a different conclusion vs "what actually matters, given the various limits of the truck, and given what happens while we're towing".
The limits of the truck are 8000 pounds regardless of gear ratio. We simply don't have more payload available on like 95% of the the trucks out there.
And what happens when I'm towing: the 3.21 scoots great off the line while towing. Where it peters out is on the freeway passing a semi or getting onto an on ramp. Where I need extra power, the "granny gear" the 3.92 offers won't help one tiny bit.
And finally, I still think towing in direct drive (6th gear) is better long term for the transmission, and funny enough the 3.92 will want to tow that same load in overdrive/7th.
Combine all that with a missundertanding that both trucks must be using the same transmission gear at the same time and therefore the 3.21 puts less torque to the ground - well that's why the 3.21 is bashed so often.
I actually have no issue with the 3.92. I'd buy a truck with it if it checked all the other boxes. I just like to be honest and accurate, the 3.21 will do the job perfectly fine.
In the end it's basically a wash with both having the same final drive ratio's,but on the one hand the 3.92's in 7th are easier on u-joints /driveshaft etc., but on the other hand the 3.21's operating in 6th is easier on the transmission.The strongest gear in a transmission is always the straight through direct drive gear,whether it's an automatic or a manual transmission.I guess you could pick your poison,do you want to abuse the u-joints more,or do you want to abuse the transmission more,the u-joints are definitely cheaper and easier to replace then the transmission,lol
I'd also say we can rule out the motor mounts as being a weak link in a Ram,they've been proven to handle in excess of 1100 rwhp :Big Laugh:
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
I'll hug on that. :)
My main point was on identical fully loaded trucks it is not the same, a 3.92 in 7th and 3.21 in 6th. The end result of "work being done" may be the same, but it is less of a strain on the 3.92 truck. And like I said from the beginning it may be negligible.
Do we all agree on that?
