TPMS on 2014 dually
Keith1
V10
I have a 2014 dually and 2 sensors on one hub are bot being shown. Does this require sensor replacement or is there something I can do? Just seems kinda weird that it's both sensors on the same hub.
Thanks
Keith
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
2014 and it's 2025. 10 yes is about the max I've seen oem sensors be viable.
It is odd it's only one wheel.
My suggestion, check for any codes if you have access to a code reader. Maybe replace at least 1 of those sensors with new, either OEM (expensive) or aftermarket (less expensive but tricky as our trucks may or may not like them) is about the only way to find out. If the sensor you replace does not read then you need to look at the receiver as the sensor is the transmitter.
K
Keith1
V10
Thanks for the reply. I guess I'll see about getting a new sensor.
62Blazer
Midwest
A TPMS tool, that a tire shop should have, should be able to see if the sensor is still reading or not. If the tool can't pick them up, then they are likely dead.
