Tpms problems
FF1899
Syracuse NY
Ok guys I know it's been a little while but now I'm running into an issue I'm now quiet sure where to start. After being on the highway for a while (20 30 min) I started having my right rear tpms sensors stop reading. After a few minutes or I'm off and back to normal around the town driving the reading comes back and the light shut off. I figured at this point I just had to swap sensors. Forward now a few weeks it is still doing it but now both rear are dropping out at the same time then the left will come back a little while later the right will also. Wasnt sure if anyone has seen the problem.
2018 ram 1500 cc sport 4x4
NJMOPAR
Older and faster
ELizabeth, NJ
Try dropping 10lbs out then re-inflating and take it for a 10min ride
FF1899
FF1899
Syracuse NY
They all come back to reading after a little while but I'll give it a shot
FF1899
FF1899
Syracuse NY
Still doing the same. The LF dropped out on my trip to camp yesterday too. This morning all reading again. Pressure reading would come and go. @JB1 you got any experience or run across anything like this in your searches
jws123
nj
My tire light has been on for 2 years i gave up its a **** system all vehicles do it just ignore it.
Adamcr68
Lorton VA
Hemifever 5.7
Sorry to jump in your post with no answer wasn’t sure if I should start new one got new wheels/tires with new sensors worked fine for a month now not getting any readings & message to service tire pressure system. Any suggestions would be greatly appreciated & good luck with yours
JB1
Houston, Texas
Sorry I dont have an answer for ya, are your sensors OEM or aftermarket?
FF1899
FF1899
Syracuse NY
Aftermarket on these wheels trouble free for 3 years. It's just odd that multiple all go out at the same time and come back at the same time and only after prolonged highway driving. I figured just the norm sensor also at first but 3 dropping at the exact same moment? That leads me to believe that its something else. I pulled over the other day on the way home when they all cut out and did a scan on them. They all tested good while they weren't reading also
FF1899
FF1899
Syracuse NY
I talked to a friend at the dealer. Even though they pick up automatically they can scan and program them. He's going to try it this week and see if it helps
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
I dealt with this issue for almost three months after purchase of after market wheels. Finally put OEM sensors in and problem went away.
For this issue OEM is the only way to go.
For my stock wheels, OEM sensors lasted 8 years.
JB1
Houston, Texas
Maybe they have cheap batteries in them, I think they say the battery in the older style trucks is 5-6 years and 7-10 for the newer truck OEM version
Timl66
Ottawa
2017- Sport
What psi are you running?
FF1899
FF1899
Syracuse NY
That was my other thought. If the signal is weak but still. 3 dropping at the exact same time has me second guessing. Couldn't find the antenna with a quick look. I'll be over to the dealership for my buddy to reprogram the end of the week and I guess we will see from there
mxrider918
St. Louis
Did you ever figure out a solution? I'm fighting the same situation in my ram. Every third start the rear 2 sensors refuse to work and then a couple of starts later they work again.
mikep345
