Sorry for revivng the old thread, but... has anyone had any luck with reprogramming sensor ids with AlfaOBD? I have a 2014 1500 longhorn with two sets of wheels for winter and summer. Winter rims were the ones that came with the truck and worked fine. This spring I purchased another set of rims and used them for summer tires, however the sensors do not seem to work.
Here's what I've seen in the RF-HUB configuration, regarding the sensor ids:
1. "Working" sensors
Number Of TPMS Sensors:
Left Front Tire Sensor ID: 01915195
Right Front Tire Sensor ID: 015160203
Right Rear Tire Sensor ID: 01917428
Left Rear Tire Sensor ID: 06020584
All but one sensor are identified by 8 digits, and FR is somewhy 9 digits...
2. I've got the tire shop to read all four sensors and program new sensors' ids into the system, but still no pressure displayed. Here's what I've seen after this procedure:
Left Front Tire Sensor ID: 03321548
Right Front Tire Sensor ID: 033226117
Right Rear Tire Sensor ID: 03321852
Left Rear Tire Sensor ID: 03321795
Notice that three ids have 8 digits (as should), but FR id has 9 digits, which looks weird.
3. So I thought I can be smart and just re-enter the ID's using the AlfaOBD routine. I went and tried to put in all four sensor id sequentially:
03321548 as FL
03322611 as FR (just dropped the last digit for the sake of testing)
03321852 as RR
03321795 as RL
Each time I entered the ID and started the procedure, it looked like the BCM was reset. Here's what I see in the config after my actions:
Left Front Tire Sensor ID: 3502172
Right Front Tire Sensor ID: 3503817
Right Rear Tire Sensor ID: 3502482
Left Rear Tire Sensor ID: 35023149
Something has clearly gone very wrong here.
So I'd really appreciate if anyone could point me in the right direction.
