TPMS reset for 35s
ej132
Cummins 5.9
Hey all, been reading a few of the threads on resetting the tpms and that I need the pin form the dealer as well as a programer. can the reset of the computer be done by us or what do I have to do to reset the computer?
Tach_tech
5.7L HEMI
What’s the problem you’re having?
E
ej132
Cummins 5.9
Haha opps, forgot to mention the reason.
Truck has 35x12.5 tires on it, and so I need far less psi than factory tires, running 40psi now which is still high but the tpms alarm is going off so would like to reset the alarms preset points
JB1
Houston, Texas
Let me guess, you have a 2500HD correct?
mjf6175
NJ
cummins
Correct sir
I recently just went through this process having a '17 2500 and installing larger tires that had a MAX limit of 65lbs. You will need a programmer and your 4 digit code for your truck. Below I pasted a link to a thread on another forum (so hope I am not breaking any rules here). The thread will have more info. Also note that my screen name on the other forum is the same as here in case you have questions about that thread. Good luck........
Updated: How to set TPMS to ANY pressure - Dodge Cummins Diesel Forum
stevenmicheal
