Brew99
So a little background...bought a new 2016 in Nov 2016 that had LT 17" wheels load rated "E". The placard on the door says that 43 psi is the suggested running pressure. So am I correct in that the TPMS lower threshold is 80% of this suggested running psi. Therefore 43psi x .80 = 34.3psi or lower(when the light should come on)?
Do I need to bring all the tires back up above the suggested 43 psi in order to get the light out, or just the one which is flashing in the EVIC screen which shows all four pressures?
