TPMS warning
greychevy
Orlando, FL
Did a quick search and didn't find anything. Tire pressure is showing correctly on EVIC and not low but the tire pressure light is staying on in the dash. Any ideas? Wish I could just disable it.
pickupman66
Tennessee
What is the pressure it shows on each?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
greychevy
greychevy
Orlando, FL
Right now cold, one shows 32, one shows 37, and two show 35. On the main EVIC screen it says
Tire PSI: OK
KCTHUNDER
Kearney MO
6.7 CUMMINS
the wifes liberty did that and I filled up the lowest one to match the rest and drove down the driveway and it went off for good.... it was still plenty driveable just too low for recommended air I guess.. if that's not it sorry. you can always get a set of 4 for $50 on ebay...
greychevy
greychevy
Orlando, FL
I'll give that a try. These are new from ebay and were working fine until recently
pickupman66
Tennessee
My wife's van although a Nissan is sensitive like that too. Keep them at 35 and its happy but 32 and its not.
Barracuda556
The sensors have a threshold they need to be at to reset the lights sometimes. We deal with this at my dealership
iam_canadian22
northern ontario
Ya my truck is the same the trip setting is like 29 but need to be over 39 i believe to reset light
iam_canadian22
northern ontario
also not sure what year you have but on my 13 it tells you what to inflate to on the evic tire pressure screen
Ruiner
Alberta
Cummins
Not sure if it affects you in the same fashion but the moment I installed my HID lights the TPMS was affected. Just a theory. Pull the power to your lights and see if the TPMS goes out.
Diller
Nashville TN
6.7 HO Cummins
Tire PSI: OK
All tires will need to be aired up to 38psi and may take up to 20 minutes of driving to reset the light.
a17ram
