SOKY_RAM
- Mar 17, 2016
- 457
- 789
- Location
- Bowling Green, KY
- 2021
- 6.4
The first thing you need to do is let some air out of the tires. You don’t need 90lbs.
get a procal snap and you can lower the psi threshold and adjust speedometer if you are going to put on bigger rubber.I caught that one on the way home. Was flipping through the dash options and was shocked at the PSI's. I guess that keeps the truck from bouncing around on the car hauler????
I also just went from a 4th gen crew cab diesel to 5th gen regular cab 6.4 with 3.73's. Im still breaking it in before i hook up to the 5th wheel this next weekend to see what performance difference in towing there is going to be. So far im impressed with the 6.4 with the 8 speed. It is much more refined and nimble than my cummins with the 68rfe. Here is a pic of the new, and the old.It was hard to part with this one but had to take advantage of the market. Plus I was running out of things to do now I have a fresh canvas. Anything I need to know about this 6.4 from the start
I went to the dealer to get a filter when I did my first oil change. The guy at the counter asked if I needed oil and told me make sure I use 0w-40 because they have one in the shop right now getting a new engine because the owner did not use the right oil. Everyone has there own opinion on a brand but dodge developed the penzoil version specifically for that engine and they warranty it if something goes wrong means it's probably well developed. If you do go with penzoil make sure you find the one ment for the SRT engines NOT the European formula!
What do you guys mean by it running quieter? The only thing I hear on start up is the exhaust flowing through the manifolds or at least that's what was explained to me. Sometimes I don't drive it for a week at a time and I don't even get much if any of a lifter tick.
It’s a great combination!2022 6.4 with 4.10s ordered on 9/11... in D1 status right now
