Does your guy know anything about an extension harness for fog lights that can hook up to my jump harness?
I have a 14 Express and have pretty much added every factory option available. Long story short your possibilities are pretty much endless. As far as a fog light harness goes contact Mpgrimm2 as previously mentioned. You will need the fog ligh harness, new headlight switch, conversion jumper harness from M2mods and then enable the code with the Alfa OBD.Does your guy know anything about an extension harness for fog lights that can hook up to my jump harness?
Sorry, most of my mods are aftermarket. Highly recommend clazzio seat covers if you want to upgrade the interior.Does your guy know anything about an extension harness for fog lights that can hook up to my jump harness?
How much did that run ya If you don’t mind me asking?I have a 14 Express and have pretty much added every factory option available. Long story short your possibilities are pretty much endless. As far as a fog light harness goes contact Mpgrimm2 as previously mentioned. You will need the fog ligh harness, new headlight switch, conversion jumper harness from M2mods and then enable the code with the Alfa OBD.
Sent from my SM-G981U1 using Tapatalk
It didn't cost me as much as some guys because I found a complete set of Laramie seats for $600 and I build most of my own harnesses myself. I've done a lot to the truck over the years so it's hard to come up with an actual amount. Most of it is just the labor of tearing the truck apart. If you shop around on Ebay and car-part.com you can find used parts pretty cheap. If I had to guess I would say 4 or 5 k. Its to hard to list everything the truck now has but the only options I'm aware of that it doesn't are rear heated seats, rain sensing wipers and front and rear park assist. I plan on adding the rain sensing wipers in the future if I ever replace my windshield but don't plan on adding the rear heated seats or park assist because I it's not necessarily something I want. The main options I have added areHow much did that run ya If you don’t mind me asking?
I have a 18 Tradesman, I bought harness from Mpgrimm2 to go from fusebox to factory harness that I bought from Allmoparparts along with factory switch. Used AlphaOBD to allow factory switch to turn fog lights on and off. I used aftermarket brackets to connect behind tow hooks for my fog lights. Pretty simple.Does anyone on this Forum know anything about upgrading parts on a 17 Ram 2500 tradesman?
Sounds to me like mpgrimm is the only way to go then. No one else has said anything different.I have a 18 Tradesman, I bought harness from Mpgrimm2 to go from fusebox to factory harness that I bought from Allmoparparts along with factory switch. Used AlphaOBD to allow factory switch to turn fog lights on and off. I used aftermarket brackets to connect behind tow hooks for my fog lights. Pretty simple.
Have you done a map light with the over head lights. I really want to do that but no idea if it can be done and if the truck has the overhead wiring.It didn't cost me as much as some guys because I found a complete set of Laramie seats for $600 and I build most of my own harnesses myself. I've done a lot to the truck over the years so it's hard to come up with an actual amount. Most of it is just the labor of tearing the truck apart. If you shop around on Ebay and car-part.com you can find used parts pretty cheap. If I had to guess I would say 4 or 5 k. Its to hard to list everything the truck now has but the only options I'm aware of that it doesn't are rear heated seats, rain sensing wipers and front and rear park assist. I plan on adding the rain sensing wipers in the future if I ever replace my windshield but don't plan on adding the rear heated seats or park assist because I it's not necessarily something I want. The main options I have added are
Push Button Start with Proximity Entry plus remote start
Heated,Vented seats with heated wheel.
Memory seats, mirrors and memory adjustable pedals
7" premium cluster
Full 8.4 Nav radio conversion.
Dual Zone Automatic Temperature Control.
Cargo Cam
Power Sliding rear window
Homelink
Power folding mirrors with blinker, puddle lights plus memory plus much more. It's kind of an addiction figuring everything out.
He does a great job and he went above and beyond helping me with the software work. I also added 8.4 radio and got a cable from him to allow rear camera view on both mirror and radio screen.Sounds to me like mpgrimm is the only way to go then. No one else has said anything different.
My truck is an Express so it came with the standard overhead console with map lights. I have since added the power sliding rear window and Homelink. Pretty sure Mike (M2mods) started making a conversion harness for the overhead console as well. It's a common upgrade. You can also install the compas module and Homelink if you chose. You will eventually need to purchase the Alfa OBD tool to enable codes for the options you want in your BCM.Have you done a map light with the over head lights. I really want to do that but no idea if it can be done and if the truck has the overhead wiring.
That’s awesome I wanna do that to mine. What do you need?He does a great job and he went above and beyond helping me with the software work. I also added 8.4 radio and got a cable from him to allow rear camera view on both mirror and radio screen.
What do you need for the auto window?My truck is an Express so it came with the standard overhead console with map lights. I have since added the power sliding rear window and Homelink. Pretty sure Mike (M2mods) started making a conversion harness for the overhead console as well. It's a common upgrade. You can also install the compas module and Homelink if you chose. You will eventually need to purchase the Alfa OBD tool to enable codes for the options you want in your BCM.
Are you referring to the power sliding rear window or the auto up and down door windows?What do you need for the auto window?
