- Jan 1, 2018
- 1,786
- 2,233
- Location
- Westminster, MD
- 2018 Power Wagon
- 6.4L Hemi
Trailer tow capacity is not on the door stickerThe numbers are on the door jamb.
Should have clarified my answer, good catch. The payload capacity will be in there, and my experience, and reading countless posts in this forum, show that payload will most likely be reached long before towing capacity is reached. The trailer weight rating can be found here. https://www.ramtrucks.com/towing/towing-guide.htmlTrailer tow capacity is not on the door sticker
it will get slightly less mpg simply because it will sit a bit higher than a truck with just the offroad package and it will have a winch which adds weight and more aggressive tires which all add up to a little mpg penalty.Does the power wagon package have any down sides like lower mpg or handling compared to the off road package
The power wagon has a taller front suspension. The power wagon uses a different part number on the track bar for this reason. The power wagon has the optional disconnecting sway bar for rock climbing, etc. If you wish to run 35's on it, it will rub unless you lift the front...level kit. Some may chime in and state they run 35's without rubbing, and that may be true if it's gonna be a pavement princess, but the it needs that extra 2 1/2 inches if you go to any amount of suspension compression or it will rub. That's my $.02 and it's worth what you paid for it, YMMV, I'm usually wrong...
If it’s only a few hundred difference, buying the Tradesman will bite you when you sell or trade it. All they’ll look at is the odometer and the trim level. Options don’t mean squat on used vehicle pricing.
also a PW 2500 has about the same cargo cap. (1300# or so) as my 1500 laramie..so why not get a 1500 PW..wouldnt it run better being quite a bit lighter..just thinking out loud.
Retired is right. They are Identical in every way. Where it Counts. The Power Wagon Tradesman is all Business. There were options I wanted that weren't available on the Tradesman. That's why I ordered the Regular Power Wagon. I looked at both well over a year. Before I decided. I ordered mine de-badged. That said. If you can get what you want in a Tradesman PW. That's what I would do. I agree with Retired. I like the Tradesman Grill a lot better myself. I also like the Chrome Bumpers, Solid Colors, and Solid Rear Window. I have had mine a little over 15 months. I Love my Truck. The PW Grill is finally starting to grow on me a little. But I've always liked the Tradesman Grill.View attachment 244985
no that is not true. the power wagon and the tradesman with pw option are the same suspension and mechanically wise.
That's True. But I bought mine thinking it will be my last Truck. I only worried about what I wanted. I didn't worry about resale value. Besides. All that Resale value comes with the initial outlay up front. The different Trim levels, are where most of the options are located. There are a few things available separately .If it’s only a few hundred difference, buying the Tradesman will bite you when you sell or trade it. All they’ll look at is the odometer and the trim level. Options don’t mean squat on used vehicle pricing.
I agree. I grew up with Solid Colors and Chrome Bumpers. I'm over 55. So I went with the extra Comfort of what's inside. I like the outside of mine. But given a Choice . I would have Chosen all of my options with the Tradesman exterior. I like my Wheels okay. But given a Choice. I like the 2016 PW Wheels better. Given another Choice. I wish we could have gotten the 6Spd. Stick that was available in 2018, with the Cummins. But attach it to the 6.4 Hemi. Remove the MDS, and add A Super Charger to it. For working/pulling at high altitudes. Leave the Truck type Cam. Where the Torque sits at the low to Mid RPM Range. Perfect for me..I am much like you though...i kind of prefer the bare bones “tough” look of the tradesman. Just wish they offered that look loaded up inside.
Agree, last thing to worry about is resale value. If money is going to factor at all, then depreciation is more the issue. That is a better measurement of the cost of owning the truck. Have to also look at financing, if done then more loss. I added 8.4 radio, function fogs, and other interior factory upgrades much cheaper than I could get in a equally provisioned truck on the lot, and made the truck exactly how I wanted.That's True. But I bought mine thinking it will be my last Truck. I only worried about what I wanted. I didn't worry about resale value. Besides. All that Resale value comes with the initial outlay up front. The different Trim levels, are where most of the options are located. There are a few things available separately .
