Tradesman with Powerwagon Package vs Powerwagon
mass-hole
Utah
I am looking to buy a Powerwagon to replace my 2014 Lariat F150. I went through the build and price on the Ram website and it seems like the Tradesman + Powerwagon package with a couple of options thrown in puts you within spitting distance of a lightly optioned Powerwagon. Am I wrong? Is their any reason to go with the Tradesman trim?
Are the Tradesmans much lighter(IE higher payload capacity) than a lightly optioned Powerwagon trim?
How does the powerwagon tow? I have a 5500 lb travel trailer that I tow around UT, WY, MT, ID and CO, so high elevations and lots of big grades. Will the 6.4L do well? My current F150 is an Ecoboost and pulls really hard but has trouble with cooling once the temperatures get hotter in the summer.
BowerPower
Arkansas
I see almost zero reason to get the tradesmen because of house close in price it is to the non tradesmen version. If you are going to be in the truck for long periods and or daily it, you will be more happy with the soft touch material in the higher end truck. It's nice not leaning your elbow on a hard plastic door panel for hours.
The tradesmen will definitely have a couple hundred pounds more payload depending on the options. With no options it's ~1500 pounds and with all of them it's ~1200 pounds. I have towed with it and over loaded the payload and it doesn't care and isn't noticeable. I haven't towed up and big mountains but think about this. The 6.4 can be had in a 3500 rated for north of 20,000 pounds of towing, so towing 6,000 pounds in the mountains should not be a problem at all.20220507_104039.jpg20220703_125642.jpg
mass-hole
mass-hole
Utah
The tradesmen will definitely have a couple hundred pounds more payload depending on the options. With no options it's ~1500 pounds and with all of them it's ~1200 pounds. I have towed with it and over loaded the payload and it doesn't care and isn't noticeable. I haven't towed up and big mountains but think about this. The 6.4 can be had in a 3500 rated for north of 20,000 pounds of towing, so towing 6,000 pounds in the mountains should not be a problem at all.View attachment 511887View attachment 511889
Nice truck. I like the green a lot but not too many around it doesnt seem like.
How are the LED headlights? That is one thing I noticed that the Tradesman doesnt have and is probably worth any price increase alone. Crappy halogen headlights arnt fun.
turkeybird56
Central Texas
MASS-HOLE: LED'S are night and day. I have an early build Bighorn (2018) and have LED lighting. Now, mine are fixed, standard reflector, not move like on higher trims but they R great. I will never buy another vehicle with Halogen lighting. Just a BOIRD's view.
Pudge
Alberta, Canada
2021 Power Wagon 75th
You‘ll almost not know 5500 lbs is back there on either the tradesmen or the PW compared to the F150. But I agree with above, if you are on the road a lot, the PW is the more comfortable truck, even without a lot of options.
Keith67
Albuquerque
I have a 2021 Power Wagon lightly optioned as follows (1450lb payload):
-Level 1 (LED headlights thank God)
-Towing Tech (360 cameras, etc.)
-Vinyl Floor
-Trailer TPMS
-Bed Utility
-Dual Alternators
I tow a 21’ travel trailer that weighs 6,100lbs wet. I’ve spent a lot of time towing through CO/NM/UT (high mountain passes and/or summer heat) and am always impressed by the truck. The ZF trans, 4.10 gears, and cooling will surprise you. On steep grades the truck is happy around 4k RPM, converter locked. It’s not 6.7 PowerStroke fast but I’ve never felt that I didn’t have enough power/torque.
Gas mileage towing is ~9mpg average with my 285/75R17 (34”) Cooper ST Maxx E load tires.
The same drivetrain in a non-Power Wagon is rated to tow a lot more than 10k lbs, so the cooling system is never a concern. Trans stays at ~170* and oil is ~220* with or without a trailer. It really feels like the PW drivetrain would pull 15k without complaining, suspension aside.
Note: I did replace the rear bump stops with SumoSprings SSR-312-47 which made a huge difference in the inherent instability when towing with a big squishy off-road truck.
retired
montana
When I bought my Power wagon in 2020 I went back and forth the dealership had several of each and was dealing because it was August of 2020 and they were not sure how covid was going to affect them. You could get a Tradesman with PW package for $45000 out the door or a PW for $50000 OTD I ultimately liked the PW's interior better and went that route. They have almost identical pay loads. I took these the day I bought mine and was deciding between a white tradesman and silver PW. Have a little regret that I did not go with the white as the grill on the tradesman looks so much better and silver is so butt ugly.
akguy09
Ellicott, Colorado
I will say that it depends on what options you want. I got the Tradesman PW because I did NOT want that big ugly Nav screen as the IPHONE is a better Nav tool. I wanted Chrome bumpers, didnt want any stripes or words on my truck and I didnt want a Center console or a sunroof. Plus I didn't want to pay for a bunch of options that I didn't want.
The nearest thing in PW trim was a Level 1 and that had stuff I didnt want.....I saved about 7K by going tradesman PW and dont miss the options and have the money in my pocket. I knew I woulndt miss the options either becuase the Cummins 3500 I sold to get my PW was a Laramie LongHorrn and I didnt like half the crap that was in it.
mass-hole
mass-hole
Utah
I think you and I are on the same page. My Lariat is pretty much fully loaded. I virtually never open the shade on my moon roof because the Utah sun will bake the interior. I dont care about leather(although heated seats are still on the want list) and I want a bench seat in the front.
BowerPower
Arkansas
Only level 3 pw get a center console, all others are bench. Moon roof is an option, one I very specifically didn't get because I would never open it. Level 1 pw is not letter seats, it's party leather like and cloth in the middle. Tradesmen can get heated seats.
Docwagon1776
Midwest
Phenomenal. I've got the adaptive that's only available in the top trim, and they are absolutely incredible, but even the lower trim LEDs are way better than halogens.
2020PW
East coast
The power wagon was once a very seldom seen vehicle and hard to locate. They have turned into grocery getters as you can see with the center console, etc.
If you plan on using it as designed get the tradesman, upgrade as desired. The PW is a good platform to start.
The only thing I don’t like about the tradesman is the interior door panel. The arm rest on it is hard as a rock, but can easily be changed.
retired
montana
for me it was the dash and the steering wheel in the Tradesman that probably influenced me the most.
BowerPower
Arkansas
They have turned into grocery getters because they don't rate them to tow or haul much. What good is a truck that can only carry 4 adults and 800 pounds in the bed? The original power wagon was a work horse of a truck for ww2 and the farm. Now it's all play and almost no work. I still think they are awesome and pretty much ignore the payload rating.
I wouldn't dismiss the tradesmen because of the headlights. Aftermarket bulbs from superbrightleds.com are a night and day difference over halogens. I have several cars that I have done it to they last forever and produce a good beam. You also have the added benefit of cheaper headlight housings if someone breaks the headlights or taillight lenses.
mass-hole
mass-hole
Utah
Yeah, <1500 lbs of payload in a 7000+ lb truck is kinda lame but its kinda how the whole 3/4 ton vs 1 ton is. Most of the time a 3/4 ton is the same as a 1 ton(especially the diesels), it just has an artificially low GVWR to skirt taxes. The Powerwagon is a much stouter truck than the door sticker suggests.
2020PW
East coast
Look at the limited mega cab CTD. PW is pretty much in line with the capacity. The PW is advertised as an off road performance product, what’s the limited mega cabs excuse?
At the end of the day, get a superduty tremor as it does both off-road and towing.
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
power wagons are as rare as hens teeth where i live. i've seen maybe 4 other ones in the last few years and they were vacationers passing through,and everyone owns a truck here due to the brutal winters.i did not seen a Tremor since they were introduced for the first year.i wanted to test drive one before i got my PW, but couldn't find one anywhere in my province.now they are a little more common,but nowhere near the Ram #'s.
ramffml
ramforum
The limited mega cabs excuse is that it has a huge cab and a heavy monster diesel engine.
The tremor is competitive with the new rebel (which also tows and does offroad). Neither of those compete with the PW IMHO.
The powerwagon is for hardcore offroading (in as much as you can with such a big truck). You will not find a more capable heavy duty offroad truck from the factory. Obviously payload and towing suffer as those are the features that allow it to offroad.
Choice is good. Ram offers a truck for every purpose, just pick the strengths of the truck depending on your usage while understanding that strengths in one area automatically mean weaknesses in other areas as they are mutually exclusive due to physics.
mass-hole
mass-hole
Utah
I like that the Ram's wheelbase is shorter. A PW is 149" vs my current F150 that is 157" and a Tremor that is 160"
I would rather have the 7.3L and 10 speed though.
62Blazer
Midwest
Power Wagon's are still fairly rare here in the midwest where I live, especially compared to Jeep Rubicon's and lifted Jeep Wranglers in general. On average I see multiple Rubicon's everytime I leave my house and not unusual if they are lifted with larger tires and a winch installed.....also guarantee that most of these lifted Jeeps have probably never even been in 4wd and definitely have never used, or at least needed, the lockers. PW's are also fairly rare on dealer lots where as most places always have Rubicon's sitting around.
Let's get real regarding the payload and towing capacity of a PW. They are capable of way more than the average 3/4 ton truck owner needs. Next time you take a road trip start counting how many 3/4 ton (2500) and 1 ton (3500) trucks to see on the road or Walmart parking lot and tell me how many are carrying any type of load or pulling a trailer. I drive a 60 mile round trip to work everyday that includes two towns and freeway between two large cities, and I bet it's at least 10 of these trucks with zero load compared to everyone pulling a trailer or a big payload in the bed. A 10,000 lb. trailer is pretty decent size trailer and that was around the maximum towing capacity rating of any 3/4 ton (2500) series trucks not that long ago. My last truck was a Chevy 2500HD with the gas engine, 4.10 gears, and all of the towing packages and it was only factory rated at 9,900 lbs. towing. I really think a lot of the people making comments that a PW can't tow have never really towed a heavy trailer, or maybe have never pulled a trailer at all. If you whole goal with a truck is constantly hauling a big trailer or big payload than you should be something else, but they probably also don't need the off-road specific items of a PW.
mmcquinn
