Trailer brake controller: purpose? / mechanism?
TonyMM
2016 RAM 1500 CC 6"4 4X4
Hi,
Can someone explain to me what is the purpose of the trailer brake controller and how it works?
Thanks
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
In short, it controls the brakes on an equipped trailer in such a manner as to promote maximum control while braking.
Most nice controllers use accelerometers to sense acceleration or deceleration in addition to having a wire jumped in from the brake switch. This allows them to adjust trailer brake pressure to match the tow vehicle brake pressure. The harder you hit the brakes, the harder the trailer brakes hit.
The most basic brake controller applies the trailer brakes at a fixed rate whenever the tow vehicle's brakes are hit. They usually have a ramp time, a time in which the brakes are applied, this is usually less than 3 seconds. This prevents heavy jerking that could occur if the trailer brakes were applied before the vehicle brakes.
T
TonyMM
Thanks!
