Trailer connection error
Hcamper
Iowa
Anyone have the trailer not connected error while driving? Was driving to Florida from Iowa and error message came on. Now sometimes I can drive 2 hours before it comes on. It comes and goes. I have unplugged the connection and plugged back in. Thanks
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
My guess is a loose connection !, When you get a chance make sure the coupling under the truck is tight ! Also I would grab a small tube of dielectric grease and put a tiny bit in each socket on the plug in ! Hope someone with better info pops in, Please Update what you find... Thanks
Hcamper
Hcamper
Iowa
That my guess too but sure can't find it.
2003F350
6.7 CTD
Definitely sounds like a loose connection, though it could also be bad grounding through the hitch itself.
Usually I put one of those short ball-on-a-loop bungies around my 7-pin round connector after I've made sure all the lights are working - I've never had an issue with any other style but I don't use them often. This keeps the connection tight. We have a trailer at work that gives everyone else problems, but because of this trick I never have an issue.
It may also be a good idea to clean your hitch ball and coupler. Most trailers use this as a 'backup ground' so to speak, and some it is the primary ground. If you have a lot of build-up inside the coupler this ground won't be made and it could cause this issue.
Hcamper
Hcamper
Iowa
Thanks I will try that. Although I didn't see the camper lights blink.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
On my 2015 the coupling is on the drivers side near the rear bumper. When I added a Curtis 5 prong splice kit to my truck when I seperated the coupling a buch of fine powder type sand/dirt fell out :O Added Dieletric there as well ! And as mention possible bad ground !
68PowerWagon
Dayton, Ohio
2022 Laramie 3500
6.7 CTD
Mine has came on a couple of times. Every time it was something in the bed of my truck shifted against the plug. It only has to loose connection for a spilt second for it to report to the truck there is a problem.
El Huapo
California Foothills, USA
2019 4X4 Warlock 1500 Classic DS w/3.55 LSD
V6 flex
Maybe the connection at the controller or under the dash if it's an add-on controller. I have had that issue there. Dielectric grease is good throughout, especially if you're in a wet area. Ever tow a boat and back into salt water to launch?
Hcamper
Hcamper
Iowa
It's not a add-on but will try dielectric grease
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Also make sure the connectors are not corroded if you have not done that yet !!
stevenmicheal
