theponyplace
Hi - I have a 2018 Ram 2500 and I tow a Double D gooseneck 4 horse stock trailer. I had an in bed hitch installed instead of the rails and spyder that I used on my old truck. The problem I am having is that the gooseneck part of the hitch is too close to the siderails of the truck and the tailgate, especially when I am travelling over uneven ground (which often occurs at horse show parking). I have lowered the trailer hitch several inches so that the trailer sits up higher, but I didn't want to do too much since it would then not be level. I noticed that when the trailer is being hitched, the truck sits down, but then self adjusts back to level. If I could get it to not self adjust, I would have plenty of clearance. Is there a solution? I did not have the fancy truck that has that add on feature - would it be worth getting? I also notcied that newer trailer models have the V support frame up under the gooseneck, while on my trailer is it below the gooseneck. Thoughts/ideas?
