I'm a big fan of the bullet proof 727 and from what I hear, the 46 rh/re are closely related to it. so I wouldn't doubt one bit they can be built to handle power.
I just finished rebuilding a 46rh and am working on a 46re. they're about as easy to work on as the 727.
incidentally what is the adjustment specs for the front and rear bands? I've heard tighten to 70 inch lbs then back off 4 full turns in the rear and 2 1/2 for the front band. is that correct?
Let me tell you how I do my band adjustment for the 727/904, A-500/A-518 and 42RE-48RE. If there is a way I can make the adjustment while the pan is off that is how I do it. I like to have a visual of the band apply lever and the support. I like to set the band apply lever 1/4" away from the piston.
Now, on the other hand, here is the procedure direct from the Factory Service Manual from 1972.
A-904 Front/Kickdown Band Adjustment
Torque the adjusting screw to 72 inch-pounds.
Back off the adjusting screw 2 full turns and tighten the lock nut. If this adjustment is being made on a transmission behind the 170 cu. in. engine back off the adjusting screw 2-5/8 turns.
A-727
Back off the adjusting screw 2 full turns. If the transmission is being used behind the 426 cu. in. engine then back off the adjusting screw 1-1/2 turns.
A-904 Rear/Reverse Band Adjustment
Back off the adjusting screw 3-1/4 turns. If the transmission is being used behind a 318 cu. in. engine then back off the adjusting screw 4 full turns.
A-727
* Front Band – tighten to 72 in-lb, back off 2-1/2 turns (all transmissions)
* Rear Band
32/42RH – Tighten to 72 in-LB, back off 4 turns
36/37/46/47RH – Tighten to 72 in-lb, back off 2 turns
1995-1996
* Front Band
42RH – tighten to 72 in-lb, back off 2-1/4 turns
46RH – tighten to 72 in-lb, back off 2-7/8 turns
47RH – tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
42RE/RH – tighten to 72 in-lb, back off 4 turns
46RE/RH – tighten to 72 in-lb, back off 2 turns
47RE/RH – tighten to 72 in-lb, back off 3 turns
1997-1998
* Front Band
42RE – tighten to 72 in-lb, back off 3-5/8 turns
46RE – tighten to 72 in-lb, back off 2-7/8 turns
47RE – tighten to 72 in-lb, back off 1-7/8 turns
* Rear Band
42RE – tighten to 72 in-lb, back off 4 turns
46RE – tighten to 72 in-lb, back off 2 turns
47RE – tighten to 72 in-lb, back off 3 turns
1999
* Front Band
42RE – tighten to 72 in-lb, back off 3 turns. (TSB 21-16-98)
47RE – tighten band adj. screw to 72 inch pounds, back off 1 7/8 turns
* Rear Band
47RE – tighten band adj. screw to 72 inch pounds, back off 3 turns
The 47RH rear band requires a 1/4″ hex driver, the front band requires a
T-30 Torx driver, the filter is held in place by two screws which require a T-20 Torx drive
2000-2002
* Front Band
42RE – Tighten band adj. screw to 72 in-lb, back off 3 turns
44RE – Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
46RE – Tighten band adj. screw to 72 in-lb, back off 2 7/8 turns
47RE – Tighten band adj. screw to 72 in-lb, back off 1 7/8 turns
* Rear Band
42RE – tighten band adj. screw to 72 inch pounds, back off 4 turns
44RE – tighten band adj. screw to 72 inch pounds, back off 4 turns
46RE – tighten band adj. screw to 72 inch pounds, back off 2 turns
2003
* Front Band
48RE – tighten band adj. screw to 72 inch pounds, back off 1-3/4 turns
* Rear Band
48RE – tighten band adj. screw to 72 inch pounds, back off 3 turns
2005
* Front Band
back off front band adjusting screw 1-3/4 turns for diesel vehicles,
or 1-1/2 turns, for V-10 vehicles.
* Rear Band
94+ Automatic Transmission Bolt and Nut Torque Specs
* Front band adjustment locknut – 30 ft-lb
* Rear band adjustment locknut – 25 ft-lb
* Transmission pan bolts – 13 ft-lb
