Trans drain plug
brownie289
Was thinking about doing my transmission drain and filter change, looks like a replacement pan is only about $40 may be worth swapping out pan and not have to mess with adding a drain plug like this should have had.
Anyone else do this?
HemiLonestar
Navy Badge Coast Guard
MD
Went to a PML cast pan with cooling fins. I was looking for max cooling with this and a 1 ton cooler.
B
brownie289
Looks very nice does it reduce your clearance by much??
HemiLonestar
MD
Not at all, the pic is misleading. It's still above the lower control arms.
HemiLonestar
MD
Isn't there a potential to "over cool"?
I guess the potential is always there, but not likely. I would say overcool would be if you could keep the temp down low enough that the trans computer locks out OD until it's warm enough. I haven't had any problems yet and it's nice to have when towing long distance or hauling stuff.
