Transfer case swap
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
I have an 01 1500 auto with a
2001-98 23 spline input, 32 spline rear slip, w/o speedo hole, manual shift, flat circular front output yoke. .840 exposed input. A/T NP231D.
I have a T-case from a 94 2500 auto and I have not dug out the shed to access the T-case yet but it could be one of two. Hopefully the NP241 DHD. But will either of these work if it is not?
1997-94 23 spline input, 32 spline slip rear, flat circular front output. w/speedo hole. 1.550 inch exposed input shaft NP241DLD.
1997-94 23 spline front input, 32 spline rear slip output, 1. 375 O.D., w/P.T.O., w/1.750 inch speedo hole, .840 inch exposed input shaft NP241DHD.
Thank you, Jimmy.
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Thats beyond my expertise there. I guess its gonna have to be a learn as you go.
Jimmy68
Jimmy68
5.2L Magnum
Ya. It's cool. I'll figure it out later. Lost shift on the fly now. Just grinds. Gotta stop to engage the T-case. Don't matter anyway as the front diff gave up locking up anyway.
Got a set of 60's to rebuild and install this summer and do a T-case swap.
stevenmicheal
