Dunk
I recently inherited a 2011 ram 1500 longhorn. It has 55k miles on the odo. The trouble code is p0934 . I know that is line pressure circuit low. The transmision functions normal when warm or after it idles a few mins. If it sits over night and i shift to reverse after 1 minute of start up the trans will slip in reverse . Let it idle one more minute and everything is normal in all gears. My dad had the pressure sensor on the right side of trans replaced, but that didnt cure the problem. Now i have the truck and ive removed the pan and filters. I found that the plastic had deformed and separated from the metal side of the flat filter. It also has a spin on filter. I'll pick up some new filters tomorrow, but my question is wouldn't that split filter cause a low pressure reading if its pulling some air thru the side of the filter? If not does anyone have any suggestions on what i need to check before reassembling. The filters were factory originals that were installed.
