Ok, back from the dodge dealer. They tell me that the problem is internal, either a valve or maybee a blocked oil passage. There are no codes thrown.The problem I have is: When I start my truck and put it in drive, it moves from 1st gear to 2nd gear no problem, but when it comes to shift in 3rd gear, it seem to not want shift as if the clutches were slipping but if I play with manual shifting a few times ( 4 or 5) then it shift and keep going to 6th gear no problem. Once I've done that, I can stop the truck, put it in park, put in neutral, put it in reverse and then take off again without a hitch. But as soon as I shut down the engine, when I restart, the problem happens again. So what happens in the transmission when I shut down the engine for that problem to reappear ?
Thank for the input !
Alonzo
